[Qgis-user] Qgis 'go2streetView' plugin: error message (Qubuntu)
celati Laurent laurent.celati at gmail.com
Fri Oct 13 07:33:35 PDT 2023
The reosolution of the problem here :
https://github.com/enricofer/go2streetview/issues/75
Le ven. 13 oct. 2023 à 13:11, celati Laurent <laurent.celati at gmail.com> a
écrit :
> Hi,
> Following to my previous message, i'm taking the liberty to post
> additional screen shots. I paste this time error message from web inspector
> of the plugin :
> Hoping will be usefull in order to resolve the problem.
> [image: Plugin_Web_Inspector_WindowDebug.jpg]
> [image: Plugin_Web_Inspector_WindowElements.jpg]
> [image: SS_go2streetview_Console.jpg]
> Le ven. 13 oct. 2023 à 10:58, celati Laurent <laurent.celati at gmail.com> a
> écrit :
>> Good morning dear all,
>> I work with Qubuntu. I installed qgis 3.32.2-Lima. I have installed the
>> latest version of the go2streetview plugin. I requested, got and set this
>> Google API key into the plugin window.
>> When I use the plugin, I get an error message in the plugin window saying
>> "small problem...an error has occurred. I paste below a screen shot showing
>> qgis interface as well as the various messages reported in the qgis logs
>> console. I replace the value of the google key with XXXXXXXXXXXXXXXXX :
>> *Logs general Menu :*
>> Code:
>>     2023-10-13T08:48:28     INFO    État de l'application
>>                  variable d'environnement QGIS_PREFIX_PATH :
>>                  Préfixe: /usr
>>                  Chemin des extensions: /usr/lib/qgis/plugins
>>                  Chemin des paquets de données: /usr/share/qgis
>>                  Nom du thème actif: default
>>                  Chemin du thème actif: /usr/share/qgis/resources/themes/default/icons/
>>                  Chemin du thème par défaut: :/images/themes/default/
>>                  Chemins de recherche SVG: /usr/share/qgis/svg/
>>                   /home/geoteca/.local/share/QGIS/QGIS3/profiles/default/svg/
>>                  Chemin de la BD utilisateur: /usr/share/qgis/resources/qgis.db
>>                  Chemin de la BD d'authentification: /home/geoteca/.local/share/QGIS/QGIS3/profiles/default/qgis-auth.db
>> *Logs go2streetview Menu :*
>> Code:2023-10-13T09:34:04     INFO    file:///home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/go2streetview/res/g2sv.html?lat=14.748027087080024&long=-17.383023740224072&width=444&height=519&heading=0&APIkey=XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX2023-10-13T09:34:04     INFO    file:///home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/go2streetview/res/g2gm.html?lat=14.748027087080024&long=-17.383023740224072&wi[1]dth=444&height=519&zoom=19&heading=0&APIkey=XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
>> *Logs python Menu :*
>> Code:2023-10-13T09:36:38     WARNING    Traceback (most recent call last):
>>               File "/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/go2streetview/go2streetview.py", line 534, in openInBrowserAction
>>               self.openInBrowserSV()
>>               File "/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/go2streetview/go2streetview.py", line 754, in openInBrowserSV
>>               pitch = str(-1 * math.floor(float(p['pitch'])))
>>              KeyError: 'pitch'
>> Code:2023-10-13T09:36:39     WARNING    Erreur Python : Une erreur est survenue lors de l'exécution du code Python : Voir le journal des erreurs Python pour plus de détails
>> Thanks so much for your usefull help.
>> Kind regards.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231013/bb3f8be0/attachment-0001.htm>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231013/bb3f8be0/attachment-0003.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231013/bb3f8be0/attachment-0004.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231013/bb3f8be0/attachment-0005.jpg>
More information about the QGIS-User mailing list
