[Qgis-user] Savingg scratch layers wont work
Marcus Levaux ml at eew.solar
Mon Oct 16 06:39:48 PDT 2023
Hi everyone, I am fairly novice to the more complicated parts of QGIS and only know the basic functionalities.
>From out of nowhere, I have made no considerable changes to the program, so wont QGIS allow me to save/make my scratch layers permanent as a Geopackage. When I try and save them, I get the following message:
[cid:image002.png at 01DA0046.D1DBE1D0]
It says that the export to vector layer failed couse of creation of datasource failed. I can manually put in the course when I save the layer and it will work, but I have never needed to do this before. It's like the program suddenly decided to save all my layer files in a space it does not have access to. Can I change this somehow so that it automatically saves in the right space and I don't have to manually input it every time?
The same applies for KML files only then it says:
[cid:image003.png at 01DA0046.FF5D5B70]
Let me know if you need more info and thank you in advance for the help!
Best Regards | Vänlig Hälsning
Marcus Leveaux
Junior Solar Projects Development Manager
M: +46 73 532 08 97
E: ml at eew.solar<mailto:ml at eew.solar>
W: www.eew.solar<http://www.eew.solar/>
[Logo  Description automatically generated]
13 Hanover Square, London, W1S 1HN
This e-mail contains confidential and privileged information intended only for the addressee(s). Please do not read it unless you are the addressee. If you are not an addressee, please call me at the number shown above, reply to this e-mail, and delete the message. You are hereby notified that any dissemination, distribution, copying, or other use of this e-mail or any attachments thereto without express written authorisation from the sender is strictly prohibited. Thank you
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231016/f776e4d8/attachment-0001.htm>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231016/f776e4d8/attachment-0003.png>
Type: image/png
Desc: image002.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231016/f776e4d8/attachment-0004.png>
Type: image/png
Desc: image003.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231016/f776e4d8/attachment-0005.png>
More information about the QGIS-User mailing list
