[Qgis-user] QGIS Themes
Thomas Klamer klamer at gbd-consult.de
Thu Oct 26 00:06:29 PDT 2023
Hello Grant,
when creating a new theme, you first need to check the layers you want
to add to said theme. After you have created the first theme and want to
create a second, you have to check a different combination of layers. If
you have done that, the "add new theme" option should be available again.
Kind regards,
Thomas
Am 26.10.23 um 03:38 schrieb Grant Boxer via QGIS-User:
> Good morning,
> I am trying to create themes in the QGIS map window but it will only allow
> me to create one theme. I wish to have one theme for my drill hole collars
> (plan view) and another theme for my cross sections (Cross_Section). After I
> have created the first theme, the add new theme option is greyed out.
> Anyone else have this problem or has a solution?
> Cheers Grant
> Perth WA
Mit freundlichen Grüßen
Thomas Klamer
Geoinformatikbüro Dassau GmbH
Rethelstrasse 153
D - 40237 Düsseldorf
Tel: +49-211-77922940
Mobil: +49-176-82002742
https://www.gbd-consult.de
Registergericht: Amtsgericht Düsseldorf, HR B 74022
Geschäftsführer: Otto Dassau
More information about the QGIS-User mailing list
