[Qgis-user] Export from print layout with masked label layer problem
Tim Fearn mountainprana.map.works at gmail.com
Thu Oct 26 09:58:10 PDT 2023
Hello all,
In trying to export a print layout which contains a contour layer where index elevation labels are using a masked symbology, Qgis crashes. After doing some research around the internet I see that this has at least in the pass been a known bug.            I’m wondering if anyone knows of a workaround or if it has been fixed and the issue persists due to my older operating system?  I have tried the export throughout several releases  Firenze 3.28 as well as Lima 3.32 running Mac OS High Sierra 10.13.6
  Thank you everyone!
Tim Fearn
Cheers,
Tim Fearn
Sent from my iPhone
More information about the QGIS-User mailing list
