[Qgis-user] Export from print layout with masked label layer problem
Alexei alexei at fastmail.net
Thu Oct 26 22:44:58 PDT 2023
Hi Tim,
I believe your issue might be related to this bug:
https://github.com/qgis/QGIS/issues/50526
Which from GitHub looks like it has not yet been addressed.
Or since you didn't say if you're using blend modes, it might be that there are multiple issues related to masking.
My only workaround was to disable label masks and use semi transparent buffers on labels instead. Not as nice an effect but at least the export will work.
Alexei
On October 26, 2023 5:58:10 PM GMT+01:00, Tim Fearn via QGIS-User <qgis-user at lists.osgeo.org> wrote:
>Hello all,
>In trying to export a print layout which contains a contour layer where index elevation labels are using a masked symbology, Qgis crashes. After doing some research around the internet I see that this has at least in the pass been a known bug.            I’m wondering if anyone knows of a workaround or if it has been fixed and the issue persists due to my older operating system?  I have tried the export throughout several releases  Firenze 3.28 as well as Lima 3.32 running Mac OS High Sierra 10.13.6
>  Thank you everyone!
>Tim Fearn
>Cheers,
>Tim Fearn
>Sent from my iPhone
>_______________________________________________
>QGIS-User mailing list
>QGIS-User at lists.osgeo.org
>List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231027/57461ba8/attachment.htm>
More information about the QGIS-User mailing list
