[Qgis-user] plugin spectral-libraries : install error message
Manolo Terranova manoloterranova at gmail.com
Tue Oct 31 11:52:49 PDT 2023
I installed it on windows and it works.
I got it from:
https://bitbucket.org/kul-reseco/spectral-libraries/downloads/
Version: spectral-libraries-1.1.3-qgis.zip
<https://bitbucket.org/kul-reseco/spectral-libraries/downloads/spectral-libraries-1.1.3-qgis.zip>
Cheers,
Manolo
On Tue, Oct 31, 2023 at 6:11 PM celati Laurent via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Good afternoon,
> i work with Qgis 3.32.2-Lima on Ubuntu.
> I would like to install and use this usefull plugin.
> https://plugins.qgis.org/plugins/spectral_libraries/
> But it seems to be deprecated? :
> So when i try to install it with qgis, i get an error message (please to
> read below) :
> If this plugin does not work anymore, it would be any alternative with
> qgis ?
> Thanks so much for your help.
> *Impossible de charger l'extension 'spectral_libraries' provoque une
> erreur lors de l'appel à sa méthode classFactory()*
> *ModuleNotFoundError: No module named 'mock'*
> Traceback (most recent call last):
>   File "/usr/lib/python3/dist-packages/qgis/utils.py", line 423, in _startPlugin
>     plugins[packageName] = package.classFactory(iface)
>   File "/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/spectral_libraries/__init__.py", line 14, in classFactory
>     from spectral_libraries.spectral_libraries_plugin import SpectralLibrariesPlugin
>   File "/usr/lib/python3/dist-packages/qgis/utils.py", line 888, in _import
>     mod = _builtin_import(name, globals, locals, fromlist, level)
>   File "/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/spectral_libraries/spectral_libraries_plugin.py", line 29, in
>     from spectral_libraries.interfaces.spectral_library_gui import SpectralLibraryWidget
>   File "/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/spectral_libraries/interfaces/spectral_library_gui.py", line 34, in
>     initResources()
>   File "/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/spectral_libraries/qps/__init__.py", line 154, in initResources
>     from .testing import initResourceFile
>   File "/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/spectral_libraries/qps/testing.py", line 40, in
>     import mock
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20231031/3d4ddb5e/attachment.htm>
More information about the QGIS-User mailing list
