[Qgis-user] Error message
Fred Wanyama
fred.wanyama at wildlife.go.ug
Fri Sep 8 02:26:19 PDT 2023
Dear Richard,
Thanks a lot, I have moved the qgis-auth.db file and it has worked well.
Regards,
Fredrick
-----Original Message-----
To: qgis-user <qgis-user at lists.osgeo.org>; fred <fred.wanyama at wildlife.go.ug>
Date: Friday, 8 September 2023 11:14 AM EAT
Subject: Re: [Qgis-user] Error message
Hi Fred,
This probably means that you opted somewhere in QGIS to save your database in the Authentication manager (secured with a password)[1].
Maybe accidently, but QGIS created a master password (sqlite) database for that.
Either try to remember the password you used, OR go into your QGIS profile directory [0] and move the qgis-auth.db file (which is the actual sqlite db) to another place. If not there search for it in your QGIS install dir?
Else try to move our QGIS profiles folder (unless you use a lot of profiles and have a lot of configuration in them) [0]
Hope this helps
Richard Duivenvoorde
[0] https://docs.qgis.org/3.28/en/docs/user_manual/introduction/qgis_configuration.html#working-with-user-profiles
[1] https://docs.qgis.org/3.28/en/docs/user_manual/auth_system/auth_overview.html#authentication-database
[2] https://docs.qgis.org/3.28/en/docs/pyqgis_developer_cookbook/authentication.html
On 9/7/23 14:36, Fred Wanyama via QGIS-User wrote:
> Greetings Team,
> Whenever I open QGIS, the following message comes.
> What should i do to stop it?
> Kind regards,
> Fredrick
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230908/d401c0b2/attachment.htm>
More information about the QGIS-User
