[Qgis-user] Possibility for Labels as Hyperlinks in PDF Output?
Keith Jenkins
kgjenkins at gmail.com
Mon Sep 11 08:09:49 PDT 2023
I don't think the label "HTML formatting" currently supports links.
The supported HTML is just a subset of HTML, mainly focused on visual
styles:
The HTML formatting option enables the proper rendering of some HTML
tags to customize the label. The supported HTML tags are:
* Color, applicable to text, underline, strikethrough, and overline
* Font properties (font family, font size, bold and italic)
* Superscript and subscript components in text
https://docs.qgis.org/testing/en/docs/user_manual/style_library/label_settings.html#text-tab
Keith
On Mon, Sep 11, 2023 at 9:28 AM Mike Treglia via QGIS-User
<qgis-user at lists.osgeo.org> wrote:
> Hi all,
> Working on a project where the desired output is PDF map, where the labels are hyperlinks. From searching around, it seems like there are, at least historically, some challenges related to this functionality and Qt, which might still be present?
> I'm finding that in the Print Composer in QGIS, I can add a label that functions as a hyperlink in an exported PDF (using the "render as HTML" functionality"), but labels associated with a layer, placed in the main map window, do not function as hyperlinks when exported as a PDF.
> Thus, wanted to check if maybe either I'm missing something - like this is/should be possible, or if not directly, maybe there's an efficient work-around? I'm working in QGIS 3.32-2 most immediately for testing this, on Windows.
> Thanks, all, for any insights!
> Mike
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
More information about the QGIS-User
