[Qgis-user] Possibility for Labels as Hyperlinks in PDF Output?
Mike Treglia mtreglia at gmail.com
Mon Sep 11 06:28:28 PDT 2023
Hi all,
Working on a project where the desired output is PDF map, where the labels
are hyperlinks. From searching around, it seems like there are, at least
historically, some challenges related to this functionality and Qt, which
might still be present?
I'm finding that in the Print Composer in QGIS, I can add a label that
functions as a hyperlink in an exported PDF (using the "render as HTML"
functionality"), but labels associated with a layer, placed in the main map
window, do not function as hyperlinks when exported as a PDF.
Thus, wanted to check if maybe either I'm missing something - like this
is/should be possible, or if not directly, maybe there's an efficient
work-around?  I'm working in QGIS 3.32-2 most immediately for testing this,
on Windows.
Thanks, all, for any insights!
Mike
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230911/d1ef15e6/attachment.htm>
More information about the QGIS-User mailing list
