[Qgis-user] Question Concerning Incorrect Color Shading in QGIS
Aqshems Nichols aqshems at berkeley.edu
Mon Sep 11 14:51:20 PDT 2023
Hello Keith,
I just toggled that feature and realized that was the issue. I do not
recall editing that feature but I may have accidentally changed it with my
mouse wheel. Thank you for bringing this to my attention. I really
appreciate your assistance.
Regards,
Aqshems
On Mon, Sep 11, 2023 at 4:17 PM Keith Jenkins <kgjenkins at gmail.com> wrote:
> I suspect the problem may have been that the blending mode was set to
> something like "difference" instead of the default "normal":
> [image: image.png]
> Keith
> On Mon, Sep 11, 2023 at 4:44 PM Aqshems Nichols via QGIS-User <
> qgis-user at lists.osgeo.org> wrote:
>> Hello Hugh and Adam,
>> I downloaded the latest version of QGIS and redid the analysis and the
>> color problem was solved. Thank you for the suggestion to open up a fresh
>> new QGIS instance.
>> Regards,
>> Aqshems
>> On Mon, Sep 11, 2023 at 12:46 PM Hugh Kelley <hghklly at gmail.com> wrote:
>>> Hi Aqshems,
>>> To help move this along, I'd recommend opening a fresh qgis instance,
>>> making a new user profile, and then dragging in your data source and
>>> rebuilding the symbology.
>>> If you get what you expect without any problems, I would then copy the
>>> layer and paste it into the original qgis file. Then see if it remains as
>>> expected.
>>> If you run into issues working through those steps this will be closer
>>> to a reproducible example of the problem. You can come back to the list to
>>> share the data source, qgis file and version info from help >> about.
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230911/93d16724/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230911/93d16724/attachment-0001.png>
More information about the QGIS-User mailing list
