[Qgis-user] Question Concerning Incorrect Color Shading in QGIS
Keith Jenkins
kgjenkins at gmail.com
Mon Sep 11 14:17:44 PDT 2023
I suspect the problem may have been that the blending mode was set to
something like "difference" instead of the default "normal":
[image: image.png]
Keith
On Mon, Sep 11, 2023 at 4:44 PM Aqshems Nichols via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Hello Hugh and Adam,
> I downloaded the latest version of QGIS and redid the analysis and the
> color problem was solved. Thank you for the suggestion to open up a fresh
> new QGIS instance.
> Regards,
> Aqshems
> On Mon, Sep 11, 2023 at 12:46 PM Hugh Kelley <hghklly at gmail.com> wrote:
>> Hi Aqshems,
>> To help move this along, I'd recommend opening a fresh qgis instance,
>> making a new user profile, and then dragging in your data source and
>> rebuilding the symbology.
>> If you get what you expect without any problems, I would then copy the
>> layer and paste it into the original qgis file. Then see if it remains as
>> expected.
>> If you run into issues working through those steps this will be closer to
>> a reproducible example of the problem. You can come back to the list to
>> share the data source, qgis file and version info from help >> about.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230911/4a5e776b/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230911/4a5e776b/attachment-0001.png>
More information about the QGIS-User
