[Qgis-user] Question Concerning Incorrect Color Shading in QGIS
Aqshems Nichols aqshems at berkeley.edu
Mon Sep 11 13:41:52 PDT 2023
Hello Hugh and Adam,
I downloaded the latest version of QGIS and redid the analysis and the
color problem was solved. Thank you for the suggestion to open up a fresh
new QGIS instance.
Regards,
Aqshems
On Mon, Sep 11, 2023 at 12:46 PM Hugh Kelley <hghklly at gmail.com> wrote:
> Hi Aqshems,
> To help move this along, I'd recommend opening a fresh qgis instance,
> making a new user profile, and then dragging in your data source and
> rebuilding the symbology.
> If you get what you expect without any problems, I would then copy the
> layer and paste it into the original qgis file. Then see if it remains as
> expected.
> If you run into issues working through those steps this will be closer to
> a reproducible example of the problem. You can come back to the list to
> share the data source, qgis file and version info from help >> about.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230911/3bc71148/attachment.htm>
More information about the QGIS-User mailing list
