[Qgis-user] QGIS-User Digest, Vol 211, Issue 21
Garth Fletcher garth at jacqcad.com
Wed Sep 13 12:28:06 PDT 2023
I've run into a similar problem (possibly the same) - that nothing shows
because the layed is panned far away from screen center. Something to do
with the Project not correctly storing the canvas center coords...
select one of your layers and then  View >> Zoom to Layer(s)
That will adjust Zoom and Pan to center and display the layer in the
display...
Best to select one of your layers that only contains stuff from your
Area of Interest
if you select some huge background layer then you will be zoomed far
enough out to display the entire layer...
Michael Edward McNeil <memcneil02 at gmail.com> wrote:
> A secondary issue, by the way, is that I apparently can't see the data after I save my QGIS project, close and re-enter the app. After re-entering QGIS the Layers pane shows all the layers, all properly check-marked for visibility, just like before, but nothing shows up in the display window ? it's totally blank white. So? I'm surviving by never (or seldom ? then reloading the data) leaving the app. But, what's going on?
> I'm running QGIS v. 3.32.2-Lima under MacOS 12.6.8.
Garth Fletcher,
More information about the QGIS-User mailing list
