[Qgis-user] QGIS-User Digest, Vol 211, Issue 21
Michael Edward McNeil memcneil02 at gmail.com
Wed Sep 13 16:05:23 PDT 2023
That did it! Now I can find and see my data when I reenter QGIS. Many thanks, Garth.
Best,
Michael McNeil
> On Sep 13, 2023, at 12:37, Garth Fletcher via QGIS-User <qgis-user at lists.osgeo.org> wrote:
> I've run into a similar problem (possibly the same) - that nothing shows because the layed is panned far away from screen center. Something to do with the Project not correctly storing the canvas center coords...
> select one of your layers and then  View >> Zoom to Layer(s)
> That will adjust Zoom and Pan to center and display the layer in the display...
> Best to select one of your layers that only contains stuff from your Area of Interest
> if you select some huge background layer then you will be zoomed far enough out to display the entire layer...
> Michael Edward McNeil <memcneil02 at gmail.com> wrote:
>> A secondary issue, by the way, is that I apparently can't see the data after I save my QGIS project, close and re-enter the app. After re-entering QGIS the Layers pane shows all the layers, all properly check-marked for visibility, just like before, but nothing shows up in the display window ? it's totally blank white. So? I'm surviving by never (or seldom ? then reloading the data) leaving the app. But, what's going on?
>> I'm running QGIS v. 3.32.2-Lima under MacOS 12.6.8.
> Garth Fletcher,
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
More information about the QGIS-User mailing list
