[Qgis-user] QGIS is great! (and fixed the broken geotagging in my Insta360 photos)
Emma Hain
emma at north-road.com
Tue Sep 19 19:58:00 PDT 2023
Thanks Adam! I am glad it worked out for you.
On Wed, 23 Aug 2023 at 18:55, Adam Nielsen via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Hi all,
> This isn't a request for help, I just wanted to give a big thanks to
> everyone involved in the development of QGIS. I have never used a
> program that seems to be able to cater to everything I might want to do.
> I recently purchased an Insta360 camera, with the goal of going walking
> and having it collect a bunch of 360 degree photos, that I could turn
> into my own private Google Street View.
> Unfortunately having just loaded the photos in using the "import
> geotagged photos" tool, it turns out that in their infinite wisdom, the
> Insta360 developers thought it would be sufficient to just use the GPS
> coordinates of the first photo taken. So now I have 400 photos at the
> exact same GPS coordinate, making the camera entirely unsuitable for
> Street View photography! (Funny how you find all the complaints on
> Google only AFTER you've bought a product.)
> However I was also recording my track using the GPS Logger app on my
> phone. I wondered whether perhaps there was a way to somehow apply
> that GPS track against the photos.
> As it turned out, the .gpx export from the app includes a track_points
> table, which has one row every second with the current GPS coordinates.
> This means there is a timestamp in that table, with GPS coordinates,
> for every timestamp in the photo table! Unfortunately one is UTC and
> the other is local time, but a little maths should be able to solve
> that.
> In the end I worked out that I could create a virtual layer, which uses
> an SQL query to join the two tables together and pick the GPS
> coordinates out of the GPS track but the rest of the data from the
> photos table. This worked perfectly and now I have a proper layer with
> each of the 400 photos at the correct location!
> This was another feature I never thought I would need but QGIS provided
> the means to get it done.
> In case anyone else ever needs to do something similar, here is the
> query I used:
> SELECT
> "photos"."fid",
> "photo",
> "filename",
> "directory",
> "ele" AS "altitude",
> "direction",
> "rotation",
> X("track_points"."geometry") AS "longitude",
> Y("track_points"."geometry") AS "latitude",
> "timestamp",
> "track_points"."geometry" AS "geometry"
> FROM "photos"
> JOIN "track_points"
> ON unixepoch("track_points"."time") = unixepoch("photos"."timestamp")
> - 36000;
> -- (36000 converts UTC+10 into UTC)
> To use it, create a new virtual layer, import the geotagged photos
> layer (and call it "photos") then add the "track_points" layer from the
> .gpx file (and call it "track_points") then click the Test button and
> it should come back as OK. Then you can add the layer.
> Just be aware that it's quite slow and makes QGIS freeze for a few
> minutes - you just have to leave it alone and it will eventually come
> back to life. The first thing I did was to quickly hide the new virtual
> layer seconds after I added it (to stop it from rendering and freezing
> QGIS), then I exported the virtual layer to a new layer in a temporary
> .gpkg file. This way I could remove the slow virtual layer and continue
> working with the faster temporary .gpkg file.
> Anyway, I just wanted to say thanks for all the effort everyone has put
> into such a fantastic program!
> Cheers,
> Adam.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
Emma Hain — Product Manager/Senior GIS Analyst
emma at north-road.com / 0414 512 782
[image: https://north-road.com]
*North Road*
Cartography • Development • Spatial Analysis
*north-road.com* <http://north-road.com>
<https://twitter.com/northroadgeo>
<https://www.linkedin.com/company/north-road-studios>
<https://www.facebook.com/North-Road-997236690392419/home>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230920/7df674fa/attachment.htm>
More information about the QGIS-User
