[Qgis-user] I really need help with a WMS source...
Marcus Levaux ml at eew.solar
Thu Sep 21 07:00:44 PDT 2023
Well now I feel silly... I got it working, it worked all along it was the "zoom scale visibility" I forgot about. I used to zoom to layer to view it but that was to large of a scale to actually view it in.. Even though it was a silly fix thank you anyyways! The quick respond helped a lot.
// Marcus Leveaux
Junior project developer, EEW
-----Ursprungligt meddelande-----
Från: Richard Duivenvoorde <rdmailings at duif.net>
Skickat: den 21 september 2023 15:51
Till: Marcus Levaux <ml at eew.solar>; qgis-user at lists.osgeo.org
Ämne: Re: Sv: [Qgis-user] I really need help with a WMS source...
[Du får inte e-post ofta från rdmailings at duif.net. Läs om varför det här är viktigt på https://aka.ms/LearnAboutSenderIdentification ]
Hi Marcus,
it's better to reply to the Mailing list, so others can learn/chip in.
The url you gave me works in my QGIS Lima. It's all EPGS:3035 layers, and they are zoom scale visible (you need to zoom in to 1:50000 or so to see them)?
In the screendump you sent, you can mouse-rightclick on a url and then choose 'Open URL', this will open/show that url in your internet browser. Like (click on this one):
https://ext-geoportal.lansstyrelsen.se/wmsproxy/wms/fastighet?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&BBOX=4569191.854855537415%2C4435522.874560302123%2C4582551.454591747373%2C4444178.582475369796&SRS=EPSG%3A3035&WIDTH=1954&HEIGHT=1266&LAYERS=granser&STYLES=&FORMAT=image%2Fpng&DPI=96&MAP_RESOLUTION=96&FORMAT_OPTIONS=dpi%3A96&TRANSPARENT=TRUE
you should see the image that QGIS is requesting for you. If not, show me what it tells you in the browser.
Also: can your Lima get other wms's, eg:
https://service.pdok.nl/kadaster/bestuurlijkegebieden/wms/v1_0?request=GetCapabilities&service=WMS
Regards,
On 9/21/23 15:31, Marcus Levaux wrote:
> This is not my speciality.... Don't understand much of this "programmer" computer language and processes, bur here I think I did it?
> The WMS currently does work in older projects but not in new ones, and it does not work in a browser, here I will share it below:
> https://ext-geoportal.lansstyrelsen.se/wmsproxy/wms/fastighet <https://ext-geoportal.lansstyrelsen.se/wmsproxy/wms/fastighet>
> // Marcus Leveaux
> Skickat: den 21 september 2023 15:22
> Till: Marcus Levaux <ml at eew.solar>; Marcus Levaux via QGIS-User <qgis-user at lists.osgeo.org>
> Ämne: Re: [Qgis-user] I really need help with a WMS source...
> [Du får inte e-post ofta från rdmailings at duif.net <mailto:rdmailings at duif.net>. Läs om varför det här är viktigt på https://aka.ms/LearnAboutSenderIdentification <https://aka.ms/LearnAboutSenderIdentification> ]
> Hi Marcus,
> Can you please open the dev-panel via F12 in QGIS and check (and report back) the url's that are failing?
> Sometimes replaying the url in a browser (as all WMS url's you can also view in a browser) already reveal issues.
> Or else maybe share the capabilities url here with us?
> Regards,
> On 9/21/23 15:18, Marcus Levaux via QGIS-User wrote:
>  > So, I really need help with a WMS source, soon wasted one full day of work on this issue and it is driving me crazy… Yesterday everything was working fine, then today I tried installing and updated version of QGIS, the latest LIMA edition. And suddenly when I create new projects, there is one specific and very important WMS source that I cannot view. It loads into the project without any issues, other WMS sources load and are visible, but this one is not. The weird thing is that I can load the troublesome WMS source in already existing projects, but not in new ones. I have no clue why. The CRS is correct and the same across all my projects and WMS sources, it’s never been an issue before. I am using the same version of QGIS I have been using for the past months, but still it wont be visible. Anyone got a clue on why this is? It drives me insane….
>  > Best Regards | Vänlig Hälsning
>  > *Marcus Leveaux*
>  > Junior Solar Projects Development Manager
>  > M: +46 73 532 08 97
>  > E: ml at eew.solar <mailto:ml at eew.solar> <mailto:ml at eew.solar <mailto:ml at eew.solar>>
>  > W: www.eew.solar <http://www.eew.solar> <http://www.eew.solar/ <http://www.eew.solar/>>
>  > Logo Description automatically generated
>  > 13 Hanover Square, London, W1S 1HN
>  > /This e-mail contains confidential and privileged information intended only for the addressee(s). Please do not read it unless you are the addressee. If you are not an addressee, please call me at the number shown above, reply to this e-mail, and delete the message. You are hereby notified that any dissemination, distribution, copying, or other use of this e-mail or any attachments thereto without express written authorisation from the sender is strictly prohibited. Thank you/
>  > _______________________________________________
>  > QGIS-User mailing list
>  > QGIS-User at lists.osgeo.org <mailto:QGIS-User at lists.osgeo.org>
>  > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>  > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
More information about the QGIS-User mailing list
