[Qgis-user] I really need help with a WMS source...
Emma Hain emma at north-road.com
Thu Sep 21 18:17:49 PDT 2023
Hey Marcus
Glad to hear that its fixed - and know you are not alone - it happens to
the best of us!
On Fri, 22 Sept 2023 at 00:00, Marcus Levaux via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Well now I feel silly... I got it working, it worked all along it was the
> "zoom scale visibility" I forgot about. I used to zoom to layer to view it
> but that was to large of a scale to actually view it in.. Even though it
> was a silly fix thank you anyyways! The quick respond helped a lot.
> // Marcus Leveaux
> Junior project developer, EEW
> -----Ursprungligt meddelande-----
> Från: Richard Duivenvoorde <rdmailings at duif.net>
> Skickat: den 21 september 2023 15:51
> Till: Marcus Levaux <ml at eew.solar>; qgis-user at lists.osgeo.org
> Ämne: Re: Sv: [Qgis-user] I really need help with a WMS source...
> [Du får inte e-post ofta från rdmailings at duif.net. Läs om varför det här
> är viktigt på https://aka.ms/LearnAboutSenderIdentification ]
> Hi Marcus,
> it's better to reply to the Mailing list, so others can learn/chip in.
> The url you gave me works in my QGIS Lima. It's all EPGS:3035 layers, and
> they are zoom scale visible (you need to zoom in to 1:50000 or so to see
> them)?
> In the screendump you sent, you can mouse-rightclick on a url and then
> choose 'Open URL', this will open/show that url in your internet browser.
> Like (click on this one):
> https://ext-geoportal.lansstyrelsen.se/wmsproxy/wms/fastighet?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&BBOX=4569191.854855537415%2C4435522.874560302123%2C4582551.454591747373%2C4444178.582475369796&SRS=EPSG%3A3035&WIDTH=1954&HEIGHT=1266&LAYERS=granser&STYLES=&FORMAT=image%2Fpng&DPI=96&MAP_RESOLUTION=96&FORMAT_OPTIONS=dpi%3A96&TRANSPARENT=TRUE
> you should see the image that QGIS is requesting for you. If not, show me
> what it tells you in the browser.
> Also: can your Lima get other wms's, eg:
> https://service.pdok.nl/kadaster/bestuurlijkegebieden/wms/v1_0?request=GetCapabilities&service=WMS
> Regards,
> On 9/21/23 15:31, Marcus Levaux wrote:
> > This is not my speciality.... Don't understand much of this "programmer"
> computer language and processes, bur here I think I did it?
> > The WMS currently does work in older projects but not in new ones, and
> it does not work in a browser, here I will share it below:
> > https://ext-geoportal.lansstyrelsen.se/wmsproxy/wms/fastighet <
> https://ext-geoportal.lansstyrelsen.se/wmsproxy/wms/fastighet>
> > // Marcus Leveaux
> > Skickat: den 21 september 2023 15:22
> > Till: Marcus Levaux <ml at eew.solar>; Marcus Levaux via QGIS-User <
> > Ämne: Re: [Qgis-user] I really need help with a WMS source...
> > [Du får inte e-post ofta från rdmailings at duif.net <mailto:
> rdmailings at duif.net>. Läs om varför det här är viktigt på
> https://aka.ms/LearnAboutSenderIdentification <
> https://aka.ms/LearnAboutSenderIdentification> ]
> > Hi Marcus,
> > Can you please open the dev-panel via F12 in QGIS and check (and report
> back) the url's that are failing?
> > Sometimes replaying the url in a browser (as all WMS url's you can also
> view in a browser) already reveal issues.
> > Or else maybe share the capabilities url here with us?
> > Regards,
> > On 9/21/23 15:18, Marcus Levaux via QGIS-User wrote:
> >  > So, I really need help with a WMS source, soon wasted one full day of
> work on this issue and it is driving me crazy… Yesterday everything was
> working fine, then today I tried installing and updated version of QGIS,
> the latest LIMA edition. And suddenly when I create new projects, there is
> one specific and very important WMS source that I cannot view. It loads
> into the project without any issues, other WMS sources load and are
> visible, but this one is not. The weird thing is that I can load the
> troublesome WMS source in already existing projects, but not in new ones. I
> have no clue why. The CRS is correct and the same across all my projects
> and WMS sources, it’s never been an issue before. I am using the same
> version of QGIS I have been using for the past months, but still it wont be
> visible. Anyone got a clue on why this is? It drives me insane….
> >  > Best Regards | Vänlig Hälsning
> >  > *Marcus Leveaux*
> >  > Junior Solar Projects Development Manager
> >  > M: +46 73 532 08 97
> >  > E: ml at eew.solar <mailto:ml at eew.solar> <mailto:ml at eew.solar <mailto:
> ml at eew.solar>>
> >  > W: www.eew.solar <http://www.eew.solar> <http://www.eew.solar/ <
> http://www.eew.solar/>>
> >  > Logo Description automatically generated
> >  > 13 Hanover Square, London, W1S 1HN
> >  > /This e-mail contains confidential and privileged information
> intended only for the addressee(s). Please do not read it unless you are
> the addressee. If you are not an addressee, please call me at the number
> shown above, reply to this e-mail, and delete the message. You are hereby
> notified that any dissemination, distribution, copying, or other use of
> this e-mail or any attachments thereto without express written
> authorisation from the sender is strictly prohibited. Thank you/
> >  > _______________________________________________
> >  > QGIS-User mailing list
> >  > QGIS-User at lists.osgeo.org <mailto:QGIS-User at lists.osgeo.org>
> >  > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user <
> https://lists.osgeo.org/mailman/listinfo/qgis-user>
> >  > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user <
Emma Hain — Product Manager/Senior GIS Analyst
emma at north-road.com / 0414 512 782
[image: https://north-road.com]
*North Road*
Cartography • Development • Spatial Analysis
*north-road.com* <http://north-road.com>
<https://twitter.com/northroadgeo>
<https://www.linkedin.com/company/north-road-studios>
<https://www.facebook.com/North-Road-997236690392419/home>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20230922/d852cfcc/attachment.htm>
More information about the QGIS-User mailing list
