[Qgis-user] Print Layout Objects don't act as Barriers
Stefan Giese (WhereGroup) stefan.giese at wheregroup.com
Mon Feb 12 02:57:55 PST 2024
Hi Alanna,
did you try this?
goto Label properties in the main properties of your layout
and there check the "Label Blocking Items"
Am 12.02.2024 um 11:45 schrieb Alanna Mitchell via QGIS-User:
> Dear QGIS community,
> I am working on some qgis projects in print layout with points that
> are labelled numerically. They are very close together points from a
> survey, and in the print layout I am inserting a legend, scale bar and
> north arrow. I cannot change the placement of these - if one map has
> them on the top left corner, I must do so for every map. However, when
> I insert the legend, as part of the map (inside the map, not outside -
> again have to keep format) it blocks some of the points, which is
> fine, however the labels are still remaining, so you can see some
> callouts and labels without the points. It looks quite messy. Is there
> a was to have these objects act as barriers? So if a point appears
> behind it, that point won't appear unless the map is moved to include
> it? Thanks for any and all help.
> Kind regards,
> Alanna
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
Mit freundlichen Grüßen
Stefan Giese
Projektleiter/Consultant
FOSSGIS Konferenz
20.-23. März 2024 in Hamburg
https://www.fossgis-konferenz.de/2024/
WhereGroup-Beiträge auf der FOSSGIS
https://wheregroup.com/unternehmen/aktuelles/
WhereGroup GmbH
Schwimmbadstr. 2
79100 Freiburg
Germany
Tel.: +49 (0)761 / 519 102 - 61
Fax: +49 (0)761 / 519 102 - 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240212/bf8a56e5/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240212/bf8a56e5/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240212/bf8a56e5/attachment-0003.png>
More information about the QGIS-User mailing list
