[Qgis-user] Distance measurement from Center - Buffer
C Hamilton adenaculture at gmail.com
Tue Feb 13 03:47:06 PST 2024
You can always use the Shape Tools plugins to draw a circle around the
points. It uses Geodesic calculations so you don't need to convert to
another projection.
Calvin
On Mon, Feb 12, 2024 at 9:31 PM krishna Ayyala via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Chris,
> Thanks for the reply. By rectangular coordinate system, can you mention
> which specific rectangular coordinate system?
> Regards.
> On Mon, Feb 12, 2024 at 5:52 PM chris hermansen <clhermansen at gmail.com>
> wrote:
>> Epsg 4326 is lat long. Make your buffers in a rectangular coordinate
>> system.
>> On Mon, Feb 12, 2024, 16:29 krishna Ayyala via QGIS-User <
>>> Hello,
>>> I have a point shape file with the projection as shown below. I have
>>> created a buffer of 16km using this point shapefile. When I measure it
>>> vertically, it reads as 32km. But when I measure it horizontally, it reads
>>> as 26km only. I have reprojected the buffer to the projected coordinate
>>> system. Despite of this, I am getting the same values. What should I do
>>> such that I can read 32kms both horizontally and vertically?
>>> Regards.
>>> [image: image.png]
>>> [image: image.png]
>>> QGIS-User mailing list
>>> QGIS-User at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240213/07a3813c/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240213/07a3813c/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240213/07a3813c/attachment-0001.png>
More information about the QGIS-User mailing list
