[Qgis-user] Upgrade process from QGIS version 3.24.1 to version 3.34.3
John Bryant johnwbryant at gmail.com
Tue Feb 20 16:22:17 PST 2024
Hi Christian, if you download the installer and run it, you'll get walked
through a few dialogues. Mostly agreeing to licences etc.
Your old installations are not automatically removed, you should manually
uninstall them once you're happy with the new one. You can run multiple
installations on a Windows machine though... for example, you could run
both the long term release and the latest release, in case you wanted to be
able to access both.
Perhaps worth considering whether your users need/want the latest release,
or the long term release (LTR is more stable, LR has newer functionality).
Note that there is a new LTR to be released in the very near future (see road
map <https://www.qgis.org/en/site/getinvolved/development/roadmap.html>).
All your user settings, UI config, data source connections, etc are saved
to your user profile which will work across all installed QGIS 3 instances.
Cheers!
John
On Wed, 21 Feb 2024 at 03:30, Christian Castro via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Hello,
> We have users running QGIS version 3.24.1 that need to be updated to the
> latest version. This would be 3.34.3 as per your website.
> What is the update process like? Just download the 3.34.3 msi file and
> click next or is something else?
> Does the installer automatically remove the 3.24.1 version or?
> And would any data they created in 3.24.1 still work in the 3.34.3 version?
> Thank you,
> *Christian Castro*
> Sr. Systems Administrator
> DLHcorp.com
> ****WARNING**** This email message (including any attachments) are to be
> treated as confidential/proprietary and may contain copyrighted or other
> legally protected information. It is intended only for the addressee(s)
> identified above. If you are not the addressee(s), or an employee or agent
> of the addressee(s), please note that any dissemination, distribution, or
> copying of this communication is strictly prohibited. If you have received
> this information in error, please destroy the information and notify the
> sender of the error. Thank you.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240221/b7cbc9ef/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240221/b7cbc9ef/attachment.png>
More information about the QGIS-User mailing list
