[Qgis-user] How to create 3d terrain from DEM?
Richard McDonnell richard.mcdonnell at opw.ie
Fri Feb 23 02:29:19 PST 2024
Quick glance at your DEM and it looks wrong, you can see the points, which to me suggests there's an issue.
As I don't 100% know the resolution of the original data you are sampling, my advice is limited to a best guess. From what I can see, online, Google elevations are based on Satellite Radar Topographic Mapping (SRTM) and has a resolution of 30m.
You might be better trying to get the original SRTM data from HERE<https://earthexplorer.usgs.gov/>
Alternatively, try using Pixel size values in the IDW Interpolation, setting it to 30 x and 30 y and see what you get.
Kind Regards,
Richard.
Richard McDonnell MSc GIS, FME Certified Professional
Geographical Information Systems Officer
Oifig na nOibreacha Poibl?
Office of Public Works
Sr?id Jonathan Swift, Baile ?tha Troim, Co na M?, C15 NX36
Jonathan Swift Street, Trim, Co Meath, C15 NX36
M +353 87 688 5964 T +353 46 942 2409
https://gov.ie/opw
To send me files larger than 30MB, please use the link below https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
Email Disclaimer: https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/
https://https://gov.ie/opw<https://www.opw.ie>
Email Disclaimer: https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/<https://www.opw.ie/en/disclaimer/>
From: QGIS-User <qgis-user-bounces at lists.osgeo.org> On Behalf Of Greg via QGIS-User
Sent: 23 February 2024 04:13
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] How to create 3d terrain from DEM?
Hello QGIS users,
We have a piece of land in Grand Lake, CO.  We want to build a house on it but the land is on a slope so we need to have a 3D terrain map to locate the house at the optimal location.  I'm mainly going off this video https://www.youtube.com/watch?v=eZZ2MVLZN4o but it doesn't work for me.
I start by making a line string in Google Earth, like this:
[cid:image006.jpg at 01DA663B.609D8310]
Then I save it as .kml file and import that file into GPS Visualizer.  That gets all the elevations along the line.  Then I Convert & add elevation as a plain text file and save the file.
Then in QGIS version 3.28.14-Firenze, I select Layer > Add Layer > Add Delimited Text Layer.  In the popup window, I open the text file and the data gets imported.  The Sample Data looks good.  I select X field as LONG, Y field as LAT, and Z field as ALT.  I leave all the other fields at their defaults and click the Add button.  All the points come in as shown:
[cid:image008.jpg at 01DA663B.609D8310]
Next, I create the DEM by double-clicking the Interpolation > IDW interpolation in the Processing Toolbox.  In the popup dialog, I click the plus button to add a layer and set its Type to Structure lines.  I set the Extent to Calculate from Layer > [name of elevation points].  I set the Rows to 100, leave the rest at their defaults, and click the Run button.  After about 5 seconds it creates a DEM as shown:
[cid:image010.jpg at 01DA663B.609D8310]
Next, I select Basemaps > Google Satellite from the HCMGIS plugin, It loads the image, overlayed on the DEM correctly:
[cid:image012.jpg at 01DA663B.609D8310]
Finally, I click the green tent icon in the in the Qgis2threejs Exporter plugin.
Instead of a nice 3D terrain as shown in the video, I get a wonky image like this:
[cid:image014.jpg at 01DA663B.609D8310]
I've spent a month trying to create a 3D terrain model, without success.  Can anybody tell me what I'm doing wrong, or recommend a workflow that actually works?  Please, no methods that require commercial software such as ArcMap, Rhino, Civil 3D, Autocad, etc.
Thank you!
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240223/fb22b797/attachment-0001.htm>
Type: image/jpeg
Desc: image006.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240223/fb22b797/attachment-0005.jpg>
Type: image/jpeg
Desc: image008.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240223/fb22b797/attachment-0006.jpg>
Type: image/jpeg
Desc: image010.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240223/fb22b797/attachment-0007.jpg>
Type: image/jpeg
Desc: image012.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240223/fb22b797/attachment-0008.jpg>
Type: image/jpeg
Desc: image014.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240223/fb22b797/attachment-0009.jpg>
More information about the QGIS-User mailing list
