[Qgis-user] QGIS through conda on Linux
Christian Naujoks 2019 at namotec.de
Mon Feb 26 07:39:10 PST 2024
Alternatively, Micromamba can be used. Micromamba is really fast:
https://waylonwalker.com/install-micromamba/
micromamba search qgis -y -c conda-forge
micromamba create -n aqgis qgis pcraster -y -c conda-forge
micromamba run -n aqgis qgis
micromamba activate aqgis
micromamba list
qgis
micromamba update
micromamba update qgis
qgis
micromamba deactivate
#Caution, this will delete the envirement aqqgis:
micromamba env remove --name aqgis
Greetings
Christian
Am Montag, dem 26.02.2024 um 09:38 -0500 schrieb Randal Hale via QGIS-
User:
> So at this point your environment should be active - type qgis in the
> terminal and it should start.
> I ignore the ICD warning. I think at some point I actually installed
> something to make it go away but it doesn't stop qgis from working.
> Randy
> On 2/26/24 09:32, Bernd Vogelgesang via QGIS-User wrote:
> > Soooo,
> > I thought to share my steps so far, so I will not have to ask again
> > in
> > some weeks ;)
> > terminal:
> > $ curl -L -O
> > "https://github.com/conda-forge/miniforge/releases/latest/download/Miniforge3-$(uname)-$(uname
> > -m).sh"
> > bash Miniforge3-$(uname)-$(uname -m).sh
> > was asked to deactivate the base environment and confirmed, but
> > somehow this did not happen, so:
> > $ conda config --set auto_activate_base false
> > $ conda create --name qgis_3.34
> > then I got warned that there is a newer version of conda (strange,
> > why
> > isn't the new version installed right away?).
> > So done as told:
> > $ conda update -n base -c conda-forge conda
> > $ conda activate qgis_3.34
> > conda install qgis=3.34
> > stuff is installed, but again the warning to update
> > finally:
> > WARNING: No ICDs were found. Either,
> > - Install a conda package providing a OpenCL implementation (pocl,
> > oclgrind, intel-compute-runtime, beignet) or
> > - Make your system-wide implementation visible by installing
> > ocl-icd-system conda package.
> > That stuff is exactly what I was messing around with for the past
> > week
> > to get the graphics card support in QGIS. Gnrrr...!
> > So, what to do now? I feel like panicking ... ;)
> > Am 26.02.24 um 14:21 schrieb Johannes Kröger (WhereGroup):
> > > Don't feel dumb, it is all written and spread out in super
> > > complicated ways but once running, it's alright-ish.
> > > Normal Miniforge3 should be fine unless you know you want pypy.
> > > Unless you know differently, try the "Miniforge3-Linux-x86_64"
> > > version.
> > > Mamba is something hidden in the background, for you it will
> > > pretend
> > > to be Conda. Conda is the original project, mamba is a faster,
> > > compatible alternative.
> > > Miniforge is something that comes with mamba "as conda" and
> > > automatically uses the big "conda-forge" repository where lots of
> > > software and libraries are available, packaged by the community.
> > > You can use the command lines from
> > > https://github.com/conda-forge/miniforge?tab=readme-ov-file#install
> > > After installation I recommend: $ conda config --set
> > > Otherwise every terminal/shell session will run using a conda
> > > environment instead of your standard system environment.
> > > Once installed, you can use the "create" line from other previous
> > > mail to install a QGIS environment. Then "conda activate
> > > qgis_3.34"
> > > to activate it in a terminal session, "qgis" in that same
> > > terminal to
> > > launch that QGIS and just close the terminal or enter "conda
> > > deactivate" to deactivate it again.
> > > Cheers, Hannes
> > > On 26.02.24 13:41, Bernd Vogelgesang wrote:
> > > > Hi Hannes,
> > > > Thanks for you answer. I played around before with those snakes
> > > > and
> > > > that's what maybe brought me into trouble.
> > > > And again, this zoo of species starts to confuse me, starting
> > > > with
> > > > the installer:
> > > > Miniforge3 or Miniforge-pypy3 ?
> > > > And when does the mamba come into play instead of the conda?
> > > > Sorry for me playing the dumb, but I almost spent a week trying
> > > > to
> > > > get things back to normal here at my desk.
> > > > Cheers,
> > > > Bernd
> > > > Am 26.02.24 um 12:35 schrieb Johannes Kröger (WhereGroup):
> > > > > Hi Bernd,
> > > > > a pragmatic solution which I have grown to like is using
> > > > > conda
> > > > > environments. Using mamba instead of the default conda via
> > > > > https://github.com/conda-forge/miniforge to reduce annoyances
> > > > > and
> > > > > then it is for example a simple "conda --create qgis_3.34
> > > > > qgis=3.34" to get a nicely isolated QGIS 3.34 with pdal etc.
> > > > > Just make sure to deactivate the base environment in your
> > > > > terminal/shell, otherwise you are trading one potential mess
> > > > > for
> > > > > another ;)
> > > > > Cheers, Hannes
> > > > > On 26.02.24 12:10, Bernd Vogelgesang via QGIS-User wrote:
> > > > > > Hi,
> > > > > > using QGIS on the "normal" ubuntu-based Linux Mint for
> > > > > > years, I
> > > > > > again managed to render my system unusable by playing
> > > > > > around too
> > > > > > much, resulting in ever crashing QGIS so I even had to
> > > > > > reactivate
> > > > > > a Windows Virtual Box to be able to work!!
> > > > > > After a hell of problems with NVIDIA graphics drivers
> > > > > > (opencl
> > > > > > support in QGIS), I finally managed to get everything to
> > > > > > work with
> > > > > > Linux Mint Debian edition ... but now had to learn that
> > > > > > Debian
> > > > > > does not provide PDAL for point cloud stuff in the
> > > > > > repositories.
> > > > > > Long story short: Can anyone give me recommendations how to
> > > > > > get
> > > > > > PDAL working with QGIS that do NOT include building PDAL
> > > > > > and QGIS
> > > > > > by myself?
> > > > > > Though I USE Linux for over 15 years,I would prefer
> > > > > > avoiding that.
> > > > > > Fumbling around with too less insight on what I am actually
> > > > > > doing
> > > > > > just led me here...
> > > > > > Cheers,
> > > > > > Bernd
> > > > > > _______________________________________________
> > > > > > QGIS-User mailing list
> > > > > > QGIS-User at lists.osgeo.org
> > > > > > List info:
> > > > > > https://lists.osgeo.org/mailman/listinfo/qgis-user
> > > > > > Unsubscribe:
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240226/a7379d41/attachment-0001.htm>
More information about the QGIS-User mailing list
