[Qgis-user] QGIS through conda on Linux
Johannes Kröger (WhereGroup)
johannes.kroeger at wheregroup.com
Mon Feb 26 08:21:03 PST 2024
I haven't tested OpenCL in a conda QGIS myself but assumed that the
instructions would work (have working OpenCL on the host, then install
the ocl-icd-system in the conda environment where you want to use it).
A quick test on a AMD Ryzen laptop just failed but even non-conda QGIS
did not pick up OpenCL support on it. :\
I hope this isn't a dead end. Sorry for not keeping your goal with
OpenCL support in mind when suggesting this initially!
On 26.02.24 15:32, Bernd Vogelgesang wrote:
> Soooo,
> I thought to share my steps so far, so I will not have to ask again in
> some weeks ;)
> terminal:
> $ curl -L -O
> "https://github.com/conda-forge/miniforge/releases/latest/download/Miniforge3-$(uname)-$(uname
> -m).sh"
> bash Miniforge3-$(uname)-$(uname -m).sh
> was asked to deactivate the base environment and confirmed, but
> somehow this did not happen, so:
> $ conda config --set auto_activate_base false
> $ conda create --name qgis_3.34
> then I got warned that there is a newer version of conda (strange, why
> isn't the new version installed right away?).
> So done as told:
> $ conda update -n base -c conda-forge conda
> $ conda activate qgis_3.34
> conda install qgis=3.34
> stuff is installed, but again the warning to update
> finally:
> WARNING: No ICDs were found. Either,
> - Install a conda package providing a OpenCL implementation (pocl,
> oclgrind, intel-compute-runtime, beignet) or
> - Make your system-wide implementation visible by installing
> ocl-icd-system conda package.
> That stuff is exactly what I was messing around with for the past week
> to get the graphics card support in QGIS. Gnrrr...!
> So, what to do now? I feel like panicking ... ;)
> Am 26.02.24 um 14:21 schrieb Johannes Kröger (WhereGroup):
>> Don't feel dumb, it is all written and spread out in super
>> complicated ways but once running, it's alright-ish.
>> Normal Miniforge3 should be fine unless you know you want pypy.
>> Unless you know differently, try the "Miniforge3-Linux-x86_64" version.
>> Mamba is something hidden in the background, for you it will pretend
>> to be Conda. Conda is the original project, mamba is a faster,
>> compatible alternative.
>> Miniforge is something that comes with mamba "as conda" and
>> automatically uses the big "conda-forge" repository where lots of
>> software and libraries are available, packaged by the community.
>> You can use the command lines from
>> https://github.com/conda-forge/miniforge?tab=readme-ov-file#install
>> After installation I recommend: $ conda config --set
>> Otherwise every terminal/shell session will run using a conda
>> environment instead of your standard system environment.
>> Once installed, you can use the "create" line from other previous
>> mail to install a QGIS environment. Then "conda activate qgis_3.34"
>> to activate it in a terminal session, "qgis" in that same terminal to
>> launch that QGIS and just close the terminal or enter "conda
>> deactivate" to deactivate it again.
>> Cheers, Hannes
>> On 26.02.24 13:41, Bernd Vogelgesang wrote:
>>> Hi Hannes,
>>> Thanks for you answer. I played around before with those snakes and
>>> that's what maybe brought me into trouble.
>>> And again, this zoo of species starts to confuse me, starting with
>>> the installer:
>>> Miniforge3 or Miniforge-pypy3 ?
>>> And when does the mamba come into play instead of the conda?
>>> Sorry for me playing the dumb, but I almost spent a week trying to
>>> get things back to normal here at my desk.
>>> Cheers,
>>> Bernd
>>> Am 26.02.24 um 12:35 schrieb Johannes Kröger (WhereGroup):
>>>> Hi Bernd,
>>>> a pragmatic solution which I have grown to like is using conda
>>>> environments. Using mamba instead of the default conda via
>>>> https://github.com/conda-forge/miniforge to reduce annoyances and
>>>> then it is for example a simple "conda --create qgis_3.34
>>>> qgis=3.34" to get a nicely isolated QGIS 3.34 with pdal etc.
>>>> Just make sure to deactivate the base environment in your
>>>> terminal/shell, otherwise you are trading one potential mess for
>>>> another ;)
>>>> Cheers, Hannes
>>>> On 26.02.24 12:10, Bernd Vogelgesang via QGIS-User wrote:
>>>>> Hi,
>>>>> using QGIS on the "normal" ubuntu-based Linux Mint for years, I
>>>>> again managed to render my system unusable by playing around too
>>>>> much, resulting in ever crashing QGIS so I even had to reactivate
>>>>> a Windows Virtual Box to be able to work!!
>>>>> After a hell of problems with NVIDIA graphics drivers (opencl
>>>>> support in QGIS), I finally managed to get everything to work with
>>>>> Linux Mint Debian edition ... but now had to learn that Debian
>>>>> does not provide PDAL for point cloud stuff in the repositories.
>>>>> Long story short: Can anyone give me recommendations how to get
>>>>> PDAL working with QGIS that do NOT include building PDAL and QGIS
>>>>> by myself?
>>>>> Though I USE Linux for over 15 years,I would prefer avoiding that.
>>>>> Fumbling around with too less insight on what I am actually doing
>>>>> just led me here...
>>>>> Cheers,
>>>>> Bernd
>>>>> _______________________________________________
>>>>> QGIS-User mailing list
>>>>> QGIS-User at lists.osgeo.org
>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Johannes Kröger / GIS-Entwickler/-Berater
FOSSGIS Konferenz
20.-23. März 2024 in Hamburg
https://www.fossgis-konferenz.de/2024/
WhereGroup-Beiträge auf der FOSSGIS
https://wheregroup.com/unternehmen/aktuelles/
WhereGroup GmbH
c/o KK03 GmbH
Lange Reihe 29
20099 Hamburg
Germany
Tel: +49 (0)228 / 90 90 38 - 36
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
More information about the QGIS-User
