[Qgis-user] launch error after recent updates
Don Harter harterc2 at att.net
Mon Feb 26 09:22:03 PST 2024
I ran this on one of my terminals.
echo $DISPLAY
:0
Try to set the DISPLAY parameter to ":0".  That is a parameter that the
X11 system uses.
You can try using the export or declare -x command.  If it works you can
add that to your .bashrc file.
But it seems like it should be set.
On 2/26/24 7:43 AM, A B via QGIS-User wrote:
> I've been running QGIS on a Chromebook for a few years.
> After the recent updates, it's no longer launching for me, which has
> never been a problem before.
> Trying to launch QGIS from the command line gives me the following
> response:
> QGIS starting in non-interactive mode not supported.
> You are seeing this message most likely because you have no DISPLAY
> environment variable set.
> Can anyone make any suggestions as to how to rectify this issue so
> that I can resume running QGIS?  Again, this was never an issue prior
> to the updates over the past few days.
> Thanks!
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240226/e3a12e08/attachment.htm>
More information about the QGIS-User mailing list
