[Qgis-user] Encoding accents on the web
chris hermansen clhermansen at gmail.com
Tue Feb 27 14:16:36 PST 2024
Robert and list,
On Tue, Feb 27, 2024 at 1:49 PM Robert Sweeny <rsweeny at mun.ca> wrote:
> Chris,
> Your suggestion makes sense. The opening line of the index.html code
> established UTF-8 as the code and which is now the same as the code for the
> Q-GIS layer. And yet, the problem persists. To make matters more
> complicated, the map has all the accents when opened from by computer, but
> looses them once uploaded.
This article by Bentley indicates that their software (and who knows, maybe
other software) expects shapefile characters to be encoded as ISO8859-1.
They recommend resaving the layer with a changed encoding.
You could try this.
https://communities.bentley.com/products/hydraulics___hydrology/w/hydraulics_and_hydrology__wiki/37273/characters-in-a-shapefile-do-not-appear-correctly-in-the-modelbuilder-preview
There's also this "encoding fixer plugin"
https://plugins.qgis.org/plugins/shapefile_encoding_fixer/
Here are some other people struggling with the same problem
https://www.reddit.com/r/QGIS/comments/y15m2a/problem_with_german_characters_in_an_attribute/
Maybe some of this will help.
Chris Hermansen · clhermansen "at" gmail "dot" com
C'est ma façon de parler.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240227/d4ac12ab/attachment.htm>
More information about the QGIS-User mailing list
