[Qgis-user] QGIS 3.22.4 - Atlas grid generated wrong images with invalid labels
Bang Pham Huu b.phamhuu at jacobs-university.de
Wed Jan 3 23:37:11 PST 2024
Hello Ludwig,
Thanks for your reply. I have the setting enabled by default already.
On 03.01.24 4:02 PM, Ludwig Kniprath wrote:
> You don't often get email from ludwig at kni-online.de. Learn why this is
> important <https://aka.ms/LearnAboutSenderIdentification>
> Hello!
> Tested, but cannot be confirmed, no such effects here (QGis 3.34.2,
> Linux Mint 21.2/UBUNTU 22.04, atlas exported as PDF and PNG).
> Maybe a problem with your labeling settings?
> Especially the settings of the "Automated Placement Engine" come to my
> mind, somewhat hidden, but accessible via
> hth
> Ludwig
> Am 03.01.24 um 09:48 schrieb Bang Pham Huu via QGIS-User:
>> Hello,
>> I'm using ubuntu 22.04 with QGIS 3.22.4 version. The question with
>> images is posted to here as well
>> https://gis.stackexchange.com/questions/473634/qgis-3-22-4-atlas-grid-generated-wrong-images-with-invalid-labels
>> I have two vector layers, one is a GeoJSON (can be downloaded
>> fromhttps://pastes.io/vtlw5surdx) which contains countries with
>> points and their coordinates in WGS84 CRS and one layer is shapefile
>> created by|Vector > Research Tools > Create Grid|then the coordinates
>> for grid extent are|-180,180,-90,90 [EPSG:4326]|and Horizontal and
>> Vertical spacing are set to 18 degrees.
>> enter image description here
>> <https://i.stack.imgur.com/d3w1D.png>
>> Then, I created New Print Layout with Atlas
>> <https://i.stack.imgur.com/Yaq7p.png>
>> and everything looks fine with this setting:
>> <https://i.stack.imgur.com/1vPDi.png>
>> But then after I chose Atlas > Export Atlas as images and I opened
>> 200 output generated tiff files on QGIS again,*it has some invalid
>> rasterized labels*like below. How can I avoid that?
>> <https://i.stack.imgur.com/bibAL.png>
>> Thanks,
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240104/dfd57478/attachment-0001.htm>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240104/dfd57478/attachment-0001.jpeg>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240104/dfd57478/attachment-0001.png>
More information about the QGIS-User mailing list
