[Qgis-user] QGIS 3.22.4 - Atlas grid generated wrong images with invalid labels
Ludwig Kniprath ludwig at kni-online.de
Wed Jan 3 07:12:07 PST 2024
Hello!
Tested, but cannot be confirmed, no such effects here (QGis 3.34.2,
Linux Mint 21.2/UBUNTU 22.04, atlas exported as PDF and PNG).
Maybe a problem with your labeling settings?
Especially the "Allow truncated labels on edges of map" settings of the
"Automated Placement Engine" come to my mind, somewhat hidden, see
https://i.stack.imgur.com/B3y3F.png
hth
Ludwig
Am 03.01.24 um 09:48 schrieb Bang Pham Huu via QGIS-User:
> Hello,
> I'm using ubuntu 22.04 with QGIS 3.22.4 version. The question with
> images is posted to here as well
> https://gis.stackexchange.com/questions/473634/qgis-3-22-4-atlas-grid-generated-wrong-images-with-invalid-labels
> I have two vector layers, one is a GeoJSON (can be downloaded
> fromhttps://pastes.io/vtlw5surdx) which contains countries with points
> and their coordinates in WGS84 CRS and one layer is shapefile created
> by|Vector > Research Tools > Create Grid|then the coordinates for grid
> extent are|-180,180,-90,90 [EPSG:4326]|and Horizontal and Vertical
> spacing are set to 18 degrees.
> enter image description here <https://i.stack.imgur.com/d3w1D.png>
> Then, I created New Print Layout with Atlas
> enter image description here <https://i.stack.imgur.com/Yaq7p.png>
> and everything looks fine with this setting:
> enter image description here <https://i.stack.imgur.com/1vPDi.png>
> But then after I chose Atlas > Export Atlas as images and I opened 200
> output generated tiff files on QGIS again,*it has some invalid
> rasterized labels*like below. How can I avoid that?
> enter image description here <https://i.stack.imgur.com/bibAL.png>
> Thanks,
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240103/21f6e950/attachment-0001.htm>
More information about the QGIS-User mailing list
