[Qgis-user] Amal Kar - India - Batch conversion of files for raster layer format from geotiff to idrisi, and simultaneously from a higher pixel resolution to a lower one.
Amal Kar
akarcaz50 at gmail.com
Thu Jan 11 07:55:43 PST 2024
Dear Drs. Richard McDonnell and Andrea Giudiceandrea,
THANK YOU VERY MUCH
for the helpful suggestions.
I have been able to use "Wrap" tool for converting the files' formats and
spatial resolutions under Batch processing.
However, i now find a small difference between the batch processing through
the"Wrap" tool and the processing of individual files.
The data is in 32-bit Unsigned Integer (UInt32), which needs to be
converted first to 16-bit Signed Integer (Int16).
When i convert the files individually, the files get converted from 32-bit
to 16-bit automatically, without asking, but under the Batch Processing
through Wrap the 32-bit data is retained.
Anyway, THANKS again for the immense help.
With Best Regards,
amal kar.
On Thu, 11 Jan 2024 at 14:41, Richard McDonnell <richard.mcdonnell at opw.ie>
wrote:
> Hi,
> One solution is to use Warp, found under *Raster* à *Projections *à *Warp
> (reproject)*
> This will allow you to specify a resolution and also change the file type.
> Kind Regards,
> Richard
> Richard McDonnell MSc GIS, FME Certified Professional
> *FRM Data Management*
> Oifig na nOibreacha Poiblí
> Office of Public Works
> Sráid Jonathan Swift, Baile Átha Troim, Co na Mí, C15 NX36
> Jonathan Swift Street, Trim, Co Meath, C15 NX36
> M +353 87 688 5964 T +353 46 942 2409
> https://gov.ie/opw
> To send me files larger than 30MB, please use the link below
> https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
> Email Disclaimer:
> https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/
> https://https://gov.ie/opw <https://www.opw.ie>
> Email Disclaimer:
> <https://www.opw.ie/en/disclaimer/>
> *From:* QGIS-User <qgis-user-bounces at lists.osgeo.org> *On Behalf Of *Amal
> Kar via QGIS-User
> *Sent:* 11 January 2024 08:16
> *To:* qgis-user at lists.osgeo.org
> *Subject:* [Qgis-user] Amal Kar - India - Batch conversion of files for
> Dear Community Members,
> I am currently trying to make use of a series of Raster data files from
> Modis satellite sensors that are available in Geotiff format (.tif) and in
> the pixel resolution of 500-m.
> I downloaded the files from a USGS website, and wanted to convert each
> file into an Idrisi raster format (16 bit integer elevation data in .RST &
> .RDC files), and in 1-km pixel resolution.
> I am using the batch convert utility in my QGIS (ver. 3.18; Zurich)
> within the GDAL Toolbox, especially its "Translate (Convert Format)"
> utility under "Raster Conversion".
> While this utility converts all the files from .tif to .rst & .rdc very
> quickly and accurately, it does not have any scope of changing the pixel
> resolution (i.e., from pixel width & height of 0.00417 arc degrees for 500
> m pixels to the width & height of 0.008333333 arc degrees for the desired
> 1-km pixels).
> When i do the conversion of files individually by opening each .tif raster
> file and then exporting each ("Save as") to idrisi format, it opens a new
> window of "Save Raster Layer as....", where the options are for changing
> the "Resolution", both horizontal and vertical.
> However, changing each data file through this process, especially when i
> am dealing with a few hundreds of daily satellite data files, is very
> cumbersome. There must be some clickable tool hidden within the Tool Box,
> which i am too naive to understand and pick up (i am NOT computer-savvy,
> although i use it more often for digital analysis of my earth surface data
> in GIS).
> I shall be highly grateful if you can lead me to the appropriate tool in
> my QGIS (ver. 3.18; Zurich), which can be easily followed.
> Thanking You for Your patience, and with Kind Regards,
> amal kar.
> Dr. Amal Kar
> Former Principal Scientist and Head, Division of Natural Resources &
> Environment,
> Central Arid Zone Research Institute, Jodhpur 342003, India
> A-1/6, Baitalik Housing Society, KMDA Housing Complex,
> Baghajatin (Near Hiland Park),
> KOLKATA 700 094, India
> Email: akarcaz50 at gmail.com
Dr. Amal Kar
Environment,
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240111/3a65d37c/attachment.htm>
More information about the QGIS-User
