[Qgis-user] Visualize time data at a certain point in time
Stefan Giese (WhereGroup) stefan.giese at wheregroup.com
Mon Jan 15 02:01:44 PST 2024
Hi Marco,
  in that case I would choose "Separate Fields for Start and End
Date/Time" in the Drop down box at the Top and then use your
valid-from-attribute and a valid-to-attributefields...
Best regards
Stefan
Am 15.01.2024 um 10:21 schrieb Marco Hugentobler via QGIS-User:
> Hi all,
> I have a dataset with a valid-from-attribute and a valid-to-attribute
> and need to visualize the data at certain points in time. I'm opening
> the temporal control panel and select 'Fixed range temporal
> nagivation'. There I enter two timestamps around the point in time as
> text. To visualize another point in time, entering two timestamps as
> text is required again.
> Wouldn't it be better for this use case to have a mode where just
> entering one timestamp is required (possibly with a graphical
> date/time picker)? Or is this already possible and I just did not see it?
> Thanks,
> Marco
Mit freundlichen Grüßen
Stefan Giese
Projektleiter/Consultant
Aufwind durch Wissen!
Web-Seminare und Online-Schulungen
bei der www.foss-academy.com/
WhereGroup GmbH
Schwimmbadstr. 2
79100 Freiburg
Germany
Tel.: +49 (0)761 / 519 102 - 61
Fax: +49 (0)761 / 519 102 - 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
More information about the QGIS-User mailing list
