[Qgis-user] Import qml-style-files
Bernhard Seckinger bernhard.seckinger at bueffee.de
Wed Jan 17 23:14:59 PST 2024
Hi Nigel,
>To load the saved qml file, right-click the layer and select properties.
>Then select Symbology down the left hand options. In the main window, at
>the bottom left, there is a button called Style with a drop arrow, which
>you can select the drop options to load a saved qml.
Great, that worked. :-) Thanks a lot!
Thanks also to Keith for the alternative.
Bernhard
Bernhard Seckinger <bernhard.seckinger at bueffee.de>
More information about the QGIS-User mailing list
