[Qgis-user] building gdal for mrsid
Don Harter harterc2 at att.net
Sun Jan 21 10:17:24 PST 2024
OK thank you.  I can use checkinstall to create a .deb package.  Perhaps
with a careful choice of options and dependencies I could replace the
ubuntugis package.  With wrong dependencies  my ubuntu system was broken
and I had problems installing packages.  It wanted me to "fix" the mess,
but I would have had to delete some packages that I wanted to keep.
On 1/21/24 10:30 AM, Even Rouault wrote:
> No, this won't be a .deb, and using the past .deb for mrsid won't work
> since the switch to CMake
> General instructions to build GDAL from source are at
> https://gdal.org/development/building_from_source.html
> To install it in a location where it won't mess with with your
> packaged GDAL, do for example
> cmake .. -DCMAKE_INSTALL_PREFIX=/opt/gdal-3.8.3 (others options here
> such as -DMRSID_ROOT=... -DECW_ROOT=... )
> (or any other installation directory of your choice)
> Even
> Le 21/01/2024 à 16:08, Don Harter a écrit :
>> OK. Thanks. Those scripts don't use .deb packages so nothing would be
>> registered with dpkg.  I have had problems before with unregistered
>> packages lying around.  I just fixed such an issue with GCC.  I don't
>> even see a package that is available for libecwj2. In what directory
>> is the build script run in?  I already have gdal installed. Will it
>> overwrite the existing ubuntu locations for the gdal packages? If I
>> were to purge those packages then other packages that rely on them
>> would have unfulfilled dependencies. I see that script is for an
>> earlier version of ubuntu.  I am running :  Ubuntu 22.04.3 LTS. And
>> my gcc (gcc (GCC) 12.3.1 20230626) is newer so I have  downloaded
>> the other/newer mrsid file.
>> So if I download the source for the .deb packages and replace the
>> scripts in them with those 2 that you located for me, will that work?
>> On 1/21/24 8:51 AM, Even Rouault wrote:
>>> Hi,
>>> cf
>>> https://github.com/OSGeo/gdal/blob/master/.github/workflows/ubuntu_20.04/Dockerfile.ci#L144
>>> and
>>> https://github.com/OSGeo/gdal/blob/master/.github/workflows/ubuntu_20.04/build.sh#L15
>>> for a build recipee to build GDAL >= 3.5 with MrSID support
>>> Even
>>> Le 21/01/2024 à 03:10, Don Harter via QGIS-User a écrit :
>>>> I have been following this procedure to build gdal with mrsid
>>>> capabilities.  I had done this a while back previously but the
>>>> different dependencies between packages cause a mess.
>>>> https://trac.osgeo.org/ubuntugis/wiki/TutorialMrSid
>>>> I tried to run this command:
>>>> sudo apt-get install libgdal-mrsid-src
>>>> But that package is not available in the unbuntugis repository.
>>>> _______________________________________________
>>>> QGIS-User mailing list
>>>> QGIS-User at lists.osgeo.org
>>>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> http://www.spatialys.com
>>> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240121/f9c4df55/attachment.htm>
More information about the QGIS-User mailing list
