[Qgis-user] building gdal for mrsid
Don Harter harterc2 at att.net
Wed Jan 24 15:01:55 PST 2024
I finally got this to build.  It was at least a problem at my end.  I
had several versions of compilers and cross compilers installed.
Somehow they were getting mixed up with the linkers.  I reinstalled all
my gcc compilers and got a successful build.  I had changed all the
compile options to -no-lto from -flto etc.  I need to clean that up and
add some more meaningful options for checkinstall.
On 1/21/24 1:17 PM, Don Harter via QGIS-User wrote:
> OK thank you.  I can use checkinstall to create a .deb package.
> Perhaps with a careful choice of options and dependencies I could
> replace the ubuntugis package.  With wrong dependencies  my ubuntu
> system was broken and I had problems installing packages.  It wanted
> me to "fix" the mess, but I would have had to delete some packages
> that I wanted to keep.
> On 1/21/24 10:30 AM, Even Rouault wrote:
>> No, this won't be a .deb, and using the past .deb for mrsid won't
>> work since the switch to CMake
>> General instructions to build GDAL from source are at
>> https://gdal.org/development/building_from_source.html
>> To install it in a location where it won't mess with with your
>> packaged GDAL, do for example
>> cmake .. -DCMAKE_INSTALL_PREFIX=/opt/gdal-3.8.3 (others options here
>> such as -DMRSID_ROOT=... -DECW_ROOT=... )
>> (or any other installation directory of your choice)
>> Even
>> Le 21/01/2024 à 16:08, Don Harter a écrit :
>>> OK. Thanks. Those scripts don't use .deb packages so nothing would
>>> be registered with dpkg.  I have had problems before with
>>> unregistered packages lying around.  I just fixed such an issue with
>>> GCC.  I don't even see a package that is available for libecwj2. In
>>> what  directory is the build script run in?  I already have gdal
>>> installed. Will it overwrite the existing ubuntu locations for the
>>> gdal packages? If I were to purge those packages then other packages
>>> that rely on them would have unfulfilled dependencies. I see that
>>> script is for an earlier version of ubuntu.  I am running :  Ubuntu
>>> 22.04.3 LTS. And my gcc (gcc (GCC) 12.3.1 20230626) is newer so I
>>> have downloaded  the other/newer mrsid file.
>>> So if I download the source for the .deb packages and replace the
>>> scripts in them with those 2 that you located for me, will that work?
>>> On 1/21/24 8:51 AM, Even Rouault wrote:
>>>> Hi,
>>>> cf
>>>> https://github.com/OSGeo/gdal/blob/master/.github/workflows/ubuntu_20.04/Dockerfile.ci#L144
>>>> and
>>>> https://github.com/OSGeo/gdal/blob/master/.github/workflows/ubuntu_20.04/build.sh#L15
>>>> for a build recipee to build GDAL >= 3.5 with MrSID support
>>>> Even
>>>> Le 21/01/2024 à 03:10, Don Harter via QGIS-User a écrit :
>>>>> I have been following this procedure to build gdal with mrsid
>>>>> capabilities.  I had done this a while back previously but the
>>>>> different dependencies between packages cause a mess.
>>>>> https://trac.osgeo.org/ubuntugis/wiki/TutorialMrSid
>>>>> I tried to run this command:
>>>>> sudo apt-get install libgdal-mrsid-src
>>>>> But that package is not available in the unbuntugis repository.
>>>>> _______________________________________________
>>>>> QGIS-User mailing list
>>>>> QGIS-User at lists.osgeo.org
>>>>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> http://www.spatialys.com
>>>> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240124/dadc955e/attachment.htm>
More information about the QGIS-User mailing list
