[Qgis-user] building gdal for mrsid
Don Harter harterc2 at att.net
Mon Jan 22 20:58:27 PST 2024
I used check install and was able to build some of the required
libraries as .deb packages.  When I tried to build the latest gdal it
crashed.  Looks it might be looking for a specific version of gcc? Or
did it find my ubuntugis version of gdal?
[ 89%] Built target gcore
[ 89%] Linking CXX shared library libgdal.so
lto1: fatal error: bytecode stream in file
‘frmts/zlib/contrib/infback9/CMakeFiles/infback9.dir/infback9.c.o’
generated with LTO version 12.0 instead of the expected 11.3
compilation terminated.
lto-wrapper: fatal error: /bin/c++ returned 1 exit status
/bin/ld: error: lto-wrapper failed
collect2: error: ld returned 1 exit status
make[2]: *** [CMakeFiles/GDAL.dir/build.make:3034: libgdal.so.34.3.9.0]
Error 1
make[1]: *** [CMakeFiles/Makefile2:4957: CMakeFiles/GDAL.dir/all] Error 2
make: *** [Makefile:146: all] Error 2
:~/src/build_gdal/GDAL/build$ gcc --version
gcc (GCC) 12.3.1 20230626
On 1/21/24 10:30 AM, Even Rouault wrote:
> No, this won't be a .deb, and using the past .deb for mrsid won't work
> since the switch to CMake
> General instructions to build GDAL from source are at
> https://gdal.org/development/building_from_source.html
> To install it in a location where it won't mess with with your
> packaged GDAL, do for example
> cmake .. -DCMAKE_INSTALL_PREFIX=/opt/gdal-3.8.3 (others options here
> such as -DMRSID_ROOT=... -DECW_ROOT=... )
> (or any other installation directory of your choice)
> Even
> Le 21/01/2024 à 16:08, Don Harter a écrit :
>> OK. Thanks. Those scripts don't use .deb packages so nothing would be
>> registered with dpkg.  I have had problems before with unregistered
>> packages lying around.  I just fixed such an issue with GCC.  I don't
>> even see a package that is available for libecwj2. In what directory
>> is the build script run in?  I already have gdal installed. Will it
>> overwrite the existing ubuntu locations for the gdal packages? If I
>> were to purge those packages then other packages that rely on them
>> would have unfulfilled dependencies. I see that script is for an
>> earlier version of ubuntu.  I am running :  Ubuntu 22.04.3 LTS. And
>> my gcc (gcc (GCC) 12.3.1 20230626) is newer so I have  downloaded
>> the other/newer mrsid file.
>> So if I download the source for the .deb packages and replace the
>> scripts in them with those 2 that you located for me, will that work?
>> On 1/21/24 8:51 AM, Even Rouault wrote:
>>> Hi,
>>> cf
>>> https://github.com/OSGeo/gdal/blob/master/.github/workflows/ubuntu_20.04/Dockerfile.ci#L144
>>> and
>>> https://github.com/OSGeo/gdal/blob/master/.github/workflows/ubuntu_20.04/build.sh#L15
>>> for a build recipee to build GDAL >= 3.5 with MrSID support
>>> Even
>>> Le 21/01/2024 à 03:10, Don Harter via QGIS-User a écrit :
>>>> I have been following this procedure to build gdal with mrsid
>>>> capabilities.  I had done this a while back previously but the
>>>> different dependencies between packages cause a mess.
>>>> https://trac.osgeo.org/ubuntugis/wiki/TutorialMrSid
>>>> I tried to run this command:
>>>> sudo apt-get install libgdal-mrsid-src
>>>> But that package is not available in the unbuntugis repository.
>>>> _______________________________________________
>>>> QGIS-User mailing list
>>>> QGIS-User at lists.osgeo.org
>>>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> http://www.spatialys.com
>>> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240122/ee99ab50/attachment.htm>
More information about the QGIS-User mailing list
