[Qgis-user] Plugin available on repo but not in QGIS
Richard Duivenvoorde rdmailings at duif.net
Thu Jan 25 06:14:22 PST 2024
Mmm, so it is in QGIS
3.35
not in
3.34
while minimum version is 3.34.2 (note the .2 !)
I remember we had lengthy discussions about this.
Short solution: remove your version 2.2 and upload it again with minimum version 2.33 (or maybe 2.34.0, or 2.33.99)
Longer solution and explanation (and showing some difficulties when using version numbers :-) )
https://github.com/qgis/QGIS-Django/pull/224
and
https://github.com/qgis/QGIS-Django/pull/325
Regards,
On 1/25/24 14:39, Julien Moura (Oslandia) via QGIS-User wrote:
> Indeed, I can't find the 2.2 version in view-source:https://plugins.qgis.org/plugins/plugins.xml?qgis=3.34&experimental=true
> Le 25/01/2024 à 14:33, Jérémy Garniaux via QGIS-User a écrit :
>> Richard,
>> Thanks for chiming in.
>> Jérémy Garniaux +336 24 25 01 00 https://mapper.fr https://mapstodon.space
>> Le 25/01/2024 à 14:13, Richard Duivenvoorde a écrit :
>>> It is approved, so should be in plugins.xml
>>> BUT(!) as it is experimental, you only see it when you have the 'Show  also Experimental Plugins' checkbox checked in the repo settings.
>>> You probably have, but it is default UNchecked.
>> Indeed - it is checked though.
>> Best regards,
>> J.
>>>> _______________________________________________
>>>> QGIS-User mailing list
>>>> QGIS-User at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
More information about the QGIS-User mailing list
