[Qgis-user] Plugin available on repo but not in QGIS
Julien Moura (Oslandia) julien.moura at oslandia.com
Thu Jan 25 06:24:15 PST 2024
And prefer using a semver compliant version naming.It avoids some
headaches ;) .
Le 25/01/2024 à 15:14, Richard Duivenvoorde a écrit :
> Mmm, so it is in QGIS
> 3.35
> not in
> 3.34
> while minimum version is 3.34.2 (note the .2 !)
> I remember we had lengthy discussions about this.
> Short solution: remove your version 2.2 and upload it again with
> minimum version 2.33 (or maybe 2.34.0, or 2.33.99)
> Longer solution and explanation (and showing some difficulties when
> using version numbers :-) )
> https://github.com/qgis/QGIS-Django/pull/224
> and
> https://github.com/qgis/QGIS-Django/pull/325
> Regards,
> On 1/25/24 14:39, Julien Moura (Oslandia) via QGIS-User wrote:
>> Indeed, I can't find the 2.2 version in
>> view-source:https://plugins.qgis.org/plugins/plugins.xml?qgis=3.34&experimental=true
>> Le 25/01/2024 à 14:33, Jérémy Garniaux via QGIS-User a écrit :
>>> Richard,
>>> Thanks for chiming in.
>>> Jérémy Garniaux +336 24 25 01 00 https://mapper.fr
>>> https://mapstodon.space
>>> Le 25/01/2024 à 14:13, Richard Duivenvoorde a écrit :
>>>> It is approved, so should be in plugins.xml
>>>> BUT(!) as it is experimental, you only see it when you have the
>>>> 'Show  also Experimental Plugins' checkbox checked in the repo
>>>> settings.
>>>> You probably have, but it is default UNchecked.
>>> Indeed - it is checked though.
>>> Best regards,
>>> J.
>>>>> _______________________________________________
>>>>> QGIS-User mailing list
>>>>> QGIS-User at lists.osgeo.org
>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
Type: application/pgp-keys
Desc: OpenPGP public key
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240125/df8db7c2/attachment.key>
Type: text/vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240125/df8db7c2/attachment.vcf>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240125/df8db7c2/attachment.sig>
More information about the QGIS-User mailing list
