[Qgis-user] Atlas printing to PDF
Nigel Berjak nigel at s3.co.za
Fri Mar 1 00:22:24 PST 2024
Hi Spring
The rasters should not be a problem. If they are not referenced, QGIS
will simply revert to querying you and asking you find their correct
locations. The file sizes should be fairly irrelevant, especially if
they have the pyramids built.
Cheers.
Regards,
Nigel Berjak
Please consider the environment before printing this email.
On 2024-03-01 09:57, Springfield Harrison wrote:
> Hello Nigel,
> Okay, thanks very much, just on the verge of updating now.
> Your tip about using a copy of the project file is a good one. Will
> certainly do that.
> I hope the update will fix the Atlas printing problem but I'm not
> holding my breath.  It contains several large map raster files which
> may be the problem.
> Thanks again…
> Cheers, Spring
> On 2024-02-29 22:26, Nigel Berjak wrote:
>> Hi Spring
>> It may be worthwhile trying this. Even 3.26 final release, as an
>> interim version. Also, ensure you do not open the original project
>> file, but rather a copy, in case you save it and cannot return
>> (possibly) to using it with the older version.
>> Regards,
>> Nigel Berjak
>> On 2024-03-01 05:16, Springfield Harrison wrote:
>>> OK, thank you.  I'm using 3.16.4, perhaps I should move up to 3.32.3?
>>> Cheers, Spring
>>> On 2024-02-29 05:15, Nigel Berjak wrote:
>>>> Hi
>>>> I have had to revert to using an older version (3.32.3) for one of
>>>> my projects, where the Atlas sheets bombs the application (3.34.3).
>>>> Is this the issue you are having?
>>>> Regards,
>>>> Nigel Berjak
>>>> On 2024-02-29 13:28, Springfield Harrison via QGIS-User wrote:
>>>>> Hello,
>>>>> Printing a PDF Atlas is a total fail - 1 page if I'm lucky, mostly
>>>>> 1 blank page.  Is there a work around?
>>>>> Thanks very much.  I'm sorry if this has been already covered,
>>>>> there seems to be no searchable forum.
>>>>> Cheers, Spring Harrison
>>>>> _______________________________________________
>>>>> QGIS-User mailing list
>>>>> QGIS-User at lists.osgeo.org
>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
More information about the QGIS-User mailing list
