[Qgis-user] Atlas printing to PDF
Springfield Harrison stellargps at gmail.com
Sat Mar 2 03:10:29 PST 2024
Hi Nigel,
Okay, note that.
However, I cannot get QGIS 3.32.3 to load copies of a couple of my
projects.  It seemed to hang up while dealing with certain files which I
then went back to the original 3.16.4 and removed.  Then it would hang
up on a different file.
In a new project, 3.32.3 will load those files but not from the original
project.  Is 3.32.3 known to have problems?  It seemed to install all
right from the Windows .MSI installer.
Update: the program will actually load those files, it just takes up 10
min. to do so.  And then there are huge delays during the work session.
The files loaded individually into a new project with no problem.
Once I finally got it working, I was able to try printing the Atlas.  No
change, it just prints one blank page.  No error messages, just a fail.
Not sure what the answer is, I don't have the time to keep trying new
versions when they are mostly a disappointment.
Nevertheless, thanks very much for your thoughts…
Cheers, Spring
On 2024-03-01 00:22, Nigel Berjak wrote:
> Hi Spring
> The rasters should not be a problem. If they are not referenced, QGIS
> will simply revert to querying you and asking you find their correct
> locations. The file sizes should be fairly irrelevant, especially if
> they have the pyramids built.
> Cheers.
> Regards,
> Nigel Berjak
> Please consider the environment before printing this email.
> On 2024-03-01 09:57, Springfield Harrison wrote:
>> Hello Nigel,
>> Okay, thanks very much, just on the verge of updating now.
>> Your tip about using a copy of the project file is a good one. Will
>> certainly do that.
>> I hope the update will fix the Atlas printing problem but I'm not
>> holding my breath.  It contains several large map raster files which
>> may be the problem.
>> Thanks again…
>> Cheers, Spring
>> On 2024-02-29 22:26, Nigel Berjak wrote:
>>> Hi Spring
>>> It may be worthwhile trying this. Even 3.26 final release, as an
>>> interim version. Also, ensure you do not open the original project
>>> file, but rather a copy, in case you save it and cannot return
>>> (possibly) to using it with the older version.
>>> Regards,
>>> Nigel Berjak
>>> On 2024-03-01 05:16, Springfield Harrison wrote:
>>>> OK, thank you.  I'm using 3.16.4, perhaps I should move up to 3.32.3?
>>>> Cheers, Spring
>>>> On 2024-02-29 05:15, Nigel Berjak wrote:
>>>>> Hi
>>>>> I have had to revert to using an older version (3.32.3) for one of
>>>>> my projects, where the Atlas sheets bombs the application
>>>>> (3.34.3). Is this the issue you are having?
>>>>> Regards,
>>>>> Nigel Berjak
>>>>> On 2024-02-29 13:28, Springfield Harrison via QGIS-User wrote:
>>>>>> Hello,
>>>>>> Printing a PDF Atlas is a total fail - 1 page if I'm lucky,
>>>>>> mostly 1 blank page.  Is there a work around?
>>>>>> Thanks very much.  I'm sorry if this has been already covered,
>>>>>> there seems to be no searchable forum.
>>>>>> Cheers, Spring Harrison
>>>>>> _______________________________________________
>>>>>> QGIS-User mailing list
>>>>>> QGIS-User at lists.osgeo.org
>>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
More information about the QGIS-User mailing list
