[Qgis-user] Atlas printing to PDF
Emma Hain emma at north-road.com
Wed Mar 6 15:36:00 PST 2024
Hi Spring
I am sorry you are experiencing this. I would strongly advise you to move
up to the latest LTR of QGIS 3.36 when you can.
It sounds like there are some buggy things happening in the background, so
maybe you need a clean version.
If this was me, I would follow this workflow.
   - Open up in the original version and create a .qpt from the print layout
   - Create a new product in the latest LTR
   - Locate the old project in the Browser window
   - Expand that project and drag the files into the new product.
   - In the print layout:
      - load the qpt
      - Copy over the Atlas parameters from your old product (you can have
      both versions open at the same time)
      - Run the atlas and see if it works.
Good luck!
Cheers
Em
On Sat, 2 Mar 2024 at 21:10, Springfield Harrison via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Hi Nigel,
> Okay, note that.
> However, I cannot get QGIS 3.32.3 to load copies of a couple of my
> projects.  It seemed to hang up while dealing with certain files which I
> then went back to the original 3.16.4 and removed.  Then it would hang
> up on a different file.
> In a new project, 3.32.3 will load those files but not from the original
> project.  Is 3.32.3 known to have problems?  It seemed to install all
> right from the Windows .MSI installer.
> Update: the program will actually load those files, it just takes up 10
> min. to do so.  And then there are huge delays during the work session.
> The files loaded individually into a new project with no problem.
> Once I finally got it working, I was able to try printing the Atlas.  No
> change, it just prints one blank page.  No error messages, just a fail.
> Not sure what the answer is, I don't have the time to keep trying new
> versions when they are mostly a disappointment.
> Nevertheless, thanks very much for your thoughts…
> Cheers, Spring
> On 2024-03-01 00:22, Nigel Berjak wrote:
> > Hi Spring
> > The rasters should not be a problem. If they are not referenced, QGIS
> > will simply revert to querying you and asking you find their correct
> > locations. The file sizes should be fairly irrelevant, especially if
> > they have the pyramids built.
> > Cheers.
> > Regards,
> > Nigel Berjak
> > Please consider the environment before printing this email.
> > On 2024-03-01 09:57, Springfield Harrison wrote:
> >> Hello Nigel,
> >> Okay, thanks very much, just on the verge of updating now.
> >> Your tip about using a copy of the project file is a good one. Will
> >> certainly do that.
> >> I hope the update will fix the Atlas printing problem but I'm not
> >> holding my breath.  It contains several large map raster files which
> >> may be the problem.
> >> Thanks again…
> >> Cheers, Spring
> >> On 2024-02-29 22:26, Nigel Berjak wrote:
> >>> Hi Spring
> >>> It may be worthwhile trying this. Even 3.26 final release, as an
> >>> interim version. Also, ensure you do not open the original project
> >>> file, but rather a copy, in case you save it and cannot return
> >>> (possibly) to using it with the older version.
> >>> Regards,
> >>> Nigel Berjak
> >>> On 2024-03-01 05:16, Springfield Harrison wrote:
> >>>> OK, thank you.  I'm using 3.16.4, perhaps I should move up to 3.32.3?
> >>>> Cheers, Spring
> >>>> On 2024-02-29 05:15, Nigel Berjak wrote:
> >>>>> Hi
> >>>>> I have had to revert to using an older version (3.32.3) for one of
> >>>>> my projects, where the Atlas sheets bombs the application
> >>>>> (3.34.3). Is this the issue you are having?
> >>>>> Regards,
> >>>>> Nigel Berjak
> >>>>> On 2024-02-29 13:28, Springfield Harrison via QGIS-User wrote:
> >>>>>> Hello,
> >>>>>> Printing a PDF Atlas is a total fail - 1 page if I'm lucky,
> >>>>>> mostly 1 blank page.  Is there a work around?
> >>>>>> Thanks very much.  I'm sorry if this has been already covered,
> >>>>>> there seems to be no searchable forum.
> >>>>>> Cheers, Spring Harrison
> >>>>>> _______________________________________________
> >>>>>> QGIS-User mailing list
> >>>>>> QGIS-User at lists.osgeo.org
> >>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> >>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Emma Hain — Product Manager/Senior GIS Analyst
[image: https://north-road.com]
*North Road*
Cartography • Development • Spatial Analysis
*north-road.com* <http://north-road.com>
<https://twitter.com/northroadgeo>
<https://www.linkedin.com/company/north-road-studios>
<https://www.facebook.com/North-Road-997236690392419/home>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240307/3055418e/attachment.htm>
More information about the QGIS-User mailing list
