[Qgis-user] Atlas printing to PDF
Springfield Harrison
stellargps at gmail.com
Thu Mar 7 01:20:50 PST 2024
Hello Emma,
Thanks very much for your suggestions.
Pondering your workflow suggestions, are you suggesting that I create a
new project in a new version of QGIS by dragging the old project into a
empty project in the new version? Do I have that right? The .qpt file
is a print template?
It sounds workable but time-consuming. As it is, I'm up half the night
just trying to get some of this work done. I may give it a try but am
leery of investing more time in "run the Atlas and see if it works."
I do appreciate your help and will probably give it a try, all fingers
crossed.
Thanks again…
Cheers, Spring
On 2024-03-06 15:36, Emma Hain wrote:
> Hi Spring
> I am sorry you are experiencing this. I would strongly advise you to
> move up to the latest LTR of QGIS 3.36 when you can.
> It sounds like there are some buggy things happening in the
> background, so maybe you need a clean version.
> If this was me, I would follow this workflow.
> * Open up in the original version and create a .qpt from the print
> layout
> * Create a new product in the latest LTR
> * Locate the old project in the Browser window
> o Expand that project and drag the files into the new product.
> * In the print layout:
> o load the qpt
> o Copy over the Atlas parameters from your old product (you can
> have both versions open at the same time)
> o Run the atlas and see if it works.
> Good luck!
> Cheers
> Em
> On Sat, 2 Mar 2024 at 21:10, Springfield Harrison via QGIS-User
> <qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>> wrote:
> Hi Nigel,
> Okay, note that.
> However, I cannot get QGIS 3.32.3 to load copies of a couple of my
> projects. It seemed to hang up while dealing with certain files
> which I
> then went back to the original 3.16.4 and removed. Then it would
> hang
> up on a different file.
> In a new project, 3.32.3 will load those files but not from the
> original
> project. Is 3.32.3 known to have problems? It seemed to install all
> right from the Windows .MSI installer.
> Update: the program will actually load those files, it just takes
> up 10
> min. to do so. And then there are huge delays during the work
> session.
> The files loaded individually into a new project with no problem.
> Once I finally got it working, I was able to try printing the
> Atlas. No
> change, it just prints one blank page. No error messages, just a
> fail.
> Not sure what the answer is, I don't have the time to keep trying new
> versions when they are mostly a disappointment.
> Nevertheless, thanks very much for your thoughts…
> Cheers, Spring
> On 2024-03-01 00:22, Nigel Berjak wrote:
> > Hi Spring
> > The rasters should not be a problem. If they are not referenced,
> QGIS
> > will simply revert to querying you and asking you find their
> correct
> > locations. The file sizes should be fairly irrelevant,
> especially if
> > they have the pyramids built.
> > Cheers.
> > Regards,
> > Nigel Berjak
> > Please consider the environment before printing this email.
> > On 2024-03-01 09:57, Springfield Harrison wrote:
> >> Hello Nigel,
> >> Okay, thanks very much, just on the verge of updating now.
> >> Your tip about using a copy of the project file is a good one.
> Will
> >> certainly do that.
> >> I hope the update will fix the Atlas printing problem but I'm not
> >> holding my breath. It contains several large map raster files
> which
> >> may be the problem.
> >> Thanks again…
> >> Cheers, Spring
> >> On 2024-02-29 22:26, Nigel Berjak wrote:
> >>> Hi Spring
> >>> It may be worthwhile trying this. Even 3.26 final release, as an
> >>> interim version. Also, ensure you do not open the original
> project
> >>> file, but rather a copy, in case you save it and cannot return
> >>> (possibly) to using it with the older version.
> >>> Regards,
> >>> Nigel Berjak
> >>> On 2024-03-01 05:16, Springfield Harrison wrote:
> >>>> OK, thank you. I'm using 3.16.4, perhaps I should move up to
> 3.32.3?
> >>>> Cheers, Spring
> >>>> On 2024-02-29 05:15, Nigel Berjak wrote:
> >>>>> Hi
> >>>>> I have had to revert to using an older version (3.32.3) for
> one of
> >>>>> my projects, where the Atlas sheets bombs the application
> >>>>> (3.34.3). Is this the issue you are having?
> >>>>> Regards,
> >>>>> Nigel Berjak
> >>>>> On 2024-02-29 13:28, Springfield Harrison via QGIS-User wrote:
> >>>>>> Hello,
> >>>>>> Printing a PDF Atlas is a total fail - 1 page if I'm lucky,
> >>>>>> mostly 1 blank page. Is there a work around?
> >>>>>> Thanks very much. I'm sorry if this has been already covered,
> >>>>>> there seems to be no searchable forum.
> >>>>>> Cheers, Spring Harrison
> >>>>>> _______________________________________________
> >>>>>> QGIS-User mailing list
> >>>>>> QGIS-User at lists.osgeo.org <mailto:QGIS-User at lists.osgeo.org>
> >>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> >>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Emma Hain — Product Manager/Senior GIS Analyst
> emma at north-road.com <mailto:emma at north-road.com>
> https://north-road.com
> *North Road*
> Cartography • Development • Spatial Analysis
> *north-road.com* <http://north-road.com>
> <https://twitter.com/northroadgeo><https://www.linkedin.com/company/north-road-studios><https://www.facebook.com/North-Road-997236690392419/home>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240307/19cd0c0c/attachment.htm>
More information about the QGIS-User
