[Qgis-user] Atlas printing to PDF
Nigel Berjak - General
nigel at s3.co.za
Thu Mar 7 04:33:12 PST 2024
Hi Spring
I think that, if I am understanding Emma's workflow correctly, you do
not need to recreate the entire project, only the layout part. If I have
misunderstood, I would first try loading the same project, then creating
a new layout from the template, then reincorporating all the various
settings. If this works, it would save a lot of time.
Regards,
Nigel Berjak
Please consider the environment before printing this email.
On 2024-03-07 11:20, Springfield Harrison wrote:
> Hello Emma,
> Thanks very much for your suggestions.
> Pondering your workflow suggestions, are you suggesting that I create a
> new project in a new version of QGIS by dragging the old project into a
> empty project in the new version? Do I have that right? The .qpt file
> is a print template?
> It sounds workable but time-consuming. As it is, I'm up half the night
> just trying to get some of this work done. I may give it a try but am
> leery of investing more time in "run the Atlas and see if it works."
> I do appreciate your help and will probably give it a try, all fingers
> crossed.
> Thanks again...
> Cheers, Spring
> On 2024-03-06 15:36, Emma Hain wrote:
> Hi Spring
> I am sorry you are experiencing this. I would strongly advise you to
> move up to the latest LTR of QGIS 3.36 when you can.
> It sounds like there are some buggy things happening in the background,
> so maybe you need a clean version.
> If this was me, I would follow this workflow.
> * Open up in the original version and create a .qpt from the print
> layout
> * Create a new product in the latest LTR
> * Locate the old project in the Browser window
> * Expand that project and drag the files into the new product.
> * In the print layout:
> * load the qpt
> * Copy over the Atlas parameters from your old product (you can have
> both versions open at the same time)
> * Run the atlas and see if it works.
> Good luck!
> Cheers
> Em
> On Sat, 2 Mar 2024 at 21:10, Springfield Harrison via QGIS-User
> <qgis-user at lists.osgeo.org> wrote: Hi Nigel,
> Okay, note that.
> However, I cannot get QGIS 3.32.3 to load copies of a couple of my
> projects. It seemed to hang up while dealing with certain files which
> I
> then went back to the original 3.16.4 and removed. Then it would hang
> up on a different file.
> In a new project, 3.32.3 will load those files but not from the
> original
> project. Is 3.32.3 known to have problems? It seemed to install all
> right from the Windows .MSI installer.
> Update: the program will actually load those files, it just takes up 10
> min. to do so. And then there are huge delays during the work session.
> The files loaded individually into a new project with no problem.
> Once I finally got it working, I was able to try printing the Atlas.
> No
> change, it just prints one blank page. No error messages, just a fail.
> Not sure what the answer is, I don't have the time to keep trying new
> versions when they are mostly a disappointment.
> Nevertheless, thanks very much for your thoughts...
> Cheers, Spring
> On 2024-03-01 00:22, Nigel Berjak wrote:
>> Hi Spring
>> The rasters should not be a problem. If they are not referenced, QGIS
>> will simply revert to querying you and asking you find their correct
>> locations. The file sizes should be fairly irrelevant, especially if
>> they have the pyramids built.
>> Cheers.
>> Regards,
>> Nigel Berjak
>> On 2024-03-01 09:57, Springfield Harrison wrote:
>>> Hello Nigel,
>>> Okay, thanks very much, just on the verge of updating now.
>>> Your tip about using a copy of the project file is a good one. Will
>>> certainly do that.
>>> I hope the update will fix the Atlas printing problem but I'm not
>>> holding my breath. It contains several large map raster files which
>>> may be the problem.
>>> Thanks again...
>>> Cheers, Spring
>>> On 2024-02-29 22:26, Nigel Berjak wrote:
>>>> Hi Spring
>>>> It may be worthwhile trying this. Even 3.26 final release, as an
>>>> interim version. Also, ensure you do not open the original project
>>>> file, but rather a copy, in case you save it and cannot return
>>>> (possibly) to using it with the older version.
>>>> Regards,
>>>> Nigel Berjak
>>>> On 2024-03-01 05:16, Springfield Harrison wrote:
>>>>> OK, thank you. I'm using 3.16.4, perhaps I should move up to
>>>>> 3.32.3?
>>>>> Cheers, Spring
>>>>> On 2024-02-29 05:15, Nigel Berjak wrote:
>>>>>> Hi
>>>>>> I have had to revert to using an older version (3.32.3) for one of
>>>>>> my projects, where the Atlas sheets bombs the application
>>>>>> (3.34.3). Is this the issue you are having?
>>>>>> Regards,
>>>>>> Nigel Berjak
>>>>>> On 2024-02-29 13:28, Springfield Harrison via QGIS-User wrote:
>>>>>>> Hello,
>>>>>>> Printing a PDF Atlas is a total fail - 1 page if I'm lucky,
>>>>>>> mostly 1 blank page. Is there a work around?
>>>>>>> Thanks very much. I'm sorry if this has been already covered,
>>>>>>> there seems to be no searchable forum.
>>>>>>> Cheers, Spring Harrison
>>>>>>> _______________________________________________
>>>>>>> QGIS-User mailing list
>>>>>>> QGIS-User at lists.osgeo.org
>>>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Emma Hain -- Product Manager/Senior GIS Analyst
> emma at north-road.com
> North Road
> Cartography * Development * Spatial Analysis
> north-road.com [1]
> [2] [3] [4]
Links:
[1] http://north-road.com
[2] https://twitter.com/northroadgeo
[3] https://www.linkedin.com/company/north-road-studios
[4] https://www.facebook.com/North-Road-997236690392419/home
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240307/d705170f/attachment.htm>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240307/d705170f/attachment.gif>
More information about the QGIS-User
