[Qgis-user] Cannot erase a polygon
Gordon Wakelin-King gwk at gbenergy.com.au
Wed Mar 6 18:46:47 PST 2024
Is it possible you drew the polygon as an Annotation object instead of an object in your vector layer? Easy enough to do, and they don’t appear in the layers menu.
Gordon Wakelin-King
From: QGIS-User <qgis-user-bounces at lists.osgeo.org> On Behalf Of Jose Sanchez via QGIS-User
Sent: Thursday, March 7, 2024 1:33 PM
To: Adam Nielsen <a.nielsen at shikadi.net>; qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Cannot erase a polygon
Hi Adam,
Thanks for replying. Yes I can zoom in and out of the polygon. I also closed the Project several times and nothing happens.
If it is a QGIS bug, it means I better redo the Project? Or is ther a alternative solution?
Thanks,
Jose
Sent from Mail<https://go.microsoft.com/fwlink/?LinkId=550986> for Windows
From: Adam Nielsen<mailto:a.nielsen at shikadi.net>
Sent: miércoles, 6 de marzo de 2024 08:46 p. m.
To: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
Cc: jsanchezo.cam at gmail.com<mailto:jsanchezo.cam at gmail.com>
> I created a vector layer to make a polygon. I later accidentally
> erased the layer but the polygon was not erased. Now it seems like a
> template and hides all the layers below. Even if I turn off all
> layers, the polygon is still there. How can I erase the polygon?
Can you zoom in on the polygon or is it fixed?  If you can zoom in then
it looks like a QGIS bug, but if the polygon is fixed and you cannot
zoom in on it then it looks like a bug in your graphics card drivers.
Have you tried to close and re-open the project to see if that gets rid
of it?
Cheers,
Adam.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240307/7b05e17d/attachment.htm>
More information about the QGIS-User mailing list
