[Qgis-user] Cannot erase a polygon
Adam Nielsen a.nielsen at shikadi.net
Wed Mar 6 18:48:27 PST 2024
> Thanks for replying. Yes I can zoom in and out of the polygon. I also
> closed the Project several times and nothing happens.
> If it is a QGIS bug, it means I better redo the Project? Or is ther a
> alternative solution?
I'm sure there's a way around the problem.  It seems quite unusual.
How did you add the polygon initially?  That might shed some light on
why it's there and how to remove it.
You don't have any print layouts or anything active?
If you don't have any luck, and the project is not confidential, it
could be useful to share it so we can try it for ourselves.  You can
save a copy of the project for this, and then delete all the layers
from the copy so the only thing in the project is the polygon.  You may
even find as you do this the polygon disappears when you delete a
certain layer which might give some hints about where it's coming from.
Cheers,
Adam.
More information about the QGIS-User mailing list
