[Qgis-user] Cannot erase a polygon
DelazJ
delazj at gmail.com
Wed Mar 6 21:29:02 PST 2024
As Gordon pointed out earlier, this looks to me like an annotation display. Please read https://docs.qgis.org/3.34/en/docs/user_manual/map_views/map_view.html#interacting-with-features for deletion.
Regards,
Harrissou
Le 7 mars 2024 03:48:27 GMT+01:00, Adam Nielsen via QGIS-User <qgis-user at lists.osgeo.org> a écrit :
>> Thanks for replying. Yes I can zoom in and out of the polygon. I also
>> closed the Project several times and nothing happens.
>> If it is a QGIS bug, it means I better redo the Project? Or is ther a
>> alternative solution?
>I'm sure there's a way around the problem. It seems quite unusual.
>How did you add the polygon initially? That might shed some light on
>why it's there and how to remove it.
>You don't have any print layouts or anything active?
>If you don't have any luck, and the project is not confidential, it
>could be useful to share it so we can try it for ourselves. You can
>save a copy of the project for this, and then delete all the layers
>from the copy so the only thing in the project is the polygon. You may
>even find as you do this the polygon disappears when you delete a
>certain layer which might give some hints about where it's coming from.
>Cheers,
>Adam.
>_______________________________________________
>QGIS-User mailing list
>QGIS-User at lists.osgeo.org
>List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240307/2ac76a29/attachment.htm>
More information about the QGIS-User
