[Qgis-user] QGIS and FileGDB
Totò Fiandaca pigrecoinfinito at gmail.com
Wed Mar 6 23:27:11 PST 2024
Hi Emma,
Thanks for the reply.
As I wrote in the initial email, there are many variables at play and I
cannot always reproduce the problem, opening an issue in these conditions
is not the best choice as it would be closed immediately.
I will try to understand the problem better and maybe in the future I will
open an issue.
I wrote the email so that other users could be careful if they used this
format.
Il giorno gio 7 mar 2024 alle ore 00:38 Emma Hain <emma at north-road.com> ha
scritto:
> HI Totò
> Are you able to add this as an Issue here please.
> https://github.com/qgis/QGIS/issues
> Thanks
> Em
> On Tue, 5 Mar 2024 at 18:16, Totò Fiandaca via QGIS-User <
> qgis-user at lists.osgeo.org> wrote:
>> I use OSGeo4W on win 11 64 bit and got the problem in QGIS 3.28 and 3.34
>> For work I use both QGIS and ArcGIS PRO 3.2.2, I noticed that by
>> modifying the FileGDBs created by ArcGIS PRO in QGIS:
>> 1. saving is particularly slow;
>> 2. I often lose data, i.e. if I have an active data selection and I try
>> to update only the selection, QGIS updates the entire dataset resulting in
>> data loss.
>> I have already noticed the malfunctioning of FileGDB in QGIS for some
>> time, but I want to leave this trace, unfortunately it is not easy to
>> reproduce.
>> Greetings
>> “Se la conoscenza deve essere aperta a tutti,
>> perchè mai limitarne l’accesso?”
>> R. Stallman
>> Questo documento, allegati inclusi, contiene informazioni di proprietà di
>> FIANDACA SALVATORE e deve essere utilizzato esclusivamente dal destinatario
>> in relazione alle finalità per le quali è stato ricevuto. E' vietata
>> qualsiasi forma di riproduzione o divulgazione senza l'esplicito consenso
>> di FIANDACA SALVATORE. Qualora fosse stato ricevuto per errore si prega
>> di informare tempestivamente il mittente e distruggere la copia in proprio
>> possesso.
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Emma Hain — Product Manager/Senior GIS Analyst
> [image: https://north-road.com]
> *North Road*
> Cartography • Development • Spatial Analysis
> *north-road.com* <http://north-road.com>
> <https://twitter.com/northroadgeo>
> <https://www.linkedin.com/company/north-road-studios>
> <https://www.facebook.com/North-Road-997236690392419/home>
R. Stallman
di FIANDACA SALVATORE. Qualora fosse stato ricevuto per errore si prega di
possesso.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240307/1c20120e/attachment.htm>
More information about the QGIS-User mailing list
