[Qgis-user] Inquiry Regarding Hardware Requirements for QGIS
aday8300 aday83 at gmail.com
Fri Mar 8 04:27:19 PST 2024
Thank you!
pt., 8 mar 2024 o 08:20 Adam Nielsen <a.nielsen at shikadi.net> napisał(a):
> > What are the minimum and recommended hardware requirements for QGIS?
> For normal application use, a computer that's less than 10 years old is
> probably fine.  I'm running it on a second hand office Dell from 2017
> with no issues at all.  If your computer is capable of viewing modern
> web sites then it is capable of running QGIS quite well.
> These days computers are so fast that outside of some specific fields,
> pretty much any computer will do the job for most things.
> QGIS is not a particularly demanding application as far as these things
> go.
> > What type of graphics card is required/recommended: OpenGL (Open Graphics
> > Library), NVIDIA CUDA (Compute Unified Device Architecture), or RTX (Ray
> > Tracing eXtensions)?
> If you use any of these things for your work, you will already know
> exactly what you need.  If you have to ask the question, then you are
> unlikely to need particular support for these technologies.
> The aforementioned Dell I am using does not have a dedicated video card
> and is using Intel onboard graphics (one of the most basic setups you
> can get), and it works just fine with QGIS.
> Cheers,
> Adam.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240308/112a35c2/attachment.htm>
More information about the QGIS-User mailing list
