[Qgis-user] MacOS GeoJSON download from Google bucket
Gabor Szakacs gabor.szakacs at agreena.com
Fri Mar 8 04:50:42 PST 2024
Hi Adam, thank you very much for the feedback. I made following experience
since the post. The same file uploaded (using in both cases Chrome) by
macOS and then uploaded by windows is resulting in different
datatype assignments on the Google bucket. That gives the impression that
the OS of the file upload is setting up the data type (text or /
binary-download). I will try to find a setting in macOS to setup GeoJSON as
binary instead of a text file. Is this the right way to go?
Best,
Gabor
On Fri, 8 Mar 2024 at 04:03, Adam Nielsen <a.nielsen at shikadi.net> wrote:
> > When I use QGIS under Windows and save a vector as a GeoJSON file,
> > the uploaded file can be downloaded from the Google bucket as a file.
> When
> > I use QGIS under MacOS, the GeoJSON file opens as a text file, when you
> > push the download button in the Google bucket, instead of downloading the
> > file.
> I think this is probably down to the configuration of the web browser
> and/or the operating system.
> It's been a while, but you used to be able to configure "helper
> applications" in the browser settings that controlled what action
> happens when you open certain files.  I guess on one system it has set
> up GeoJSON as a text file but you want to change it to a
> binary/download instead.
> Alternatively when it opens up as a text file you can just save that
> (e.g. through the File menu) as it will give you the same result.
> Cheers,
> Adam.
Dr. Gabor Szakacs
Geospatial Analyst in Regenerative Agriculture
+55 11 989319305
<https://agreena.com/>
<https://agreena.com/> <https://www.linkedin.com/company/agreena>
<https://twitter.com/AgreenaApp> <https://www.instagram.com/agreenaapp/>
<https://www.facebook.com/AgreenaApp/>
We care about your personal data, read about our policy here
<https://agreena.com/privacy-policy/>.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240308/7638215d/attachment.htm>
More information about the QGIS-User mailing list
