[Qgis-user] "QgsProcessing" has no attribute 'run' (same for 'processing')
Zoltan Szecsei
zoltans at geograph.co.za
Mon Mar 11 01:30:52 PDT 2024
Apologies for asking help on what hopefully might turn out to be
trivial, but I am pretty much blue in the face googling and asking
Gemini for help.
There are 2 questions in this email:
I have a Windows 11 OSGEO4W installation QGIS 3.36.0 and grass (and more).
I use PyCharm 2023.3.4 (Community Edition) - but not yet configured
"nicely" for QGIS as I am mostly in a non-Open Source environment.
Most of the stuff I write is python is for "problem fixes" and these
python scripts ideally run on a windows command-line with a BAT file.
So, in this scenario below, I keep getting: ..... *has no
attribute 'run'
*This whether I am running inside PyCharm or on the command-line through
below batch job.
*Question #1*
*What is the correct bat file structure for running python scripts?*
I currently have [below] but is it optimal?
SET QGIS_PATH=C:\OSGeo4W\apps\qgis
call "C:\OSGeo4W\bin\o4w_env.bat"
SET PYTHONPATH=%QGIS_PATH%\python;%PYTHONPATH%
SET PATH=%QGIS_PATH%\bin;%PATH%
C:\OSGeo4W\apps\Python39\python.exe
Z:\Projects\Development\python_QGIS\qgis_tests\qgisrun.py
pause
*Question #2*
I have tried many various import options, but I cannot get past the *has
no attribute 'run'* error from python below code:
Minimalst as this code is, it should run without adding anything else,
should it?
from qgis.core import QgsProcessing
shp_inErfPoly = 'Z:\\Erven_1February2024.shp'
shp_outErfFix = 'Z:\\Erven_1February2024_FixGeo.shp'
QgsProcessing.run("native:fixgeometries", { 'INPUT': shp_inErfPoly,
'METHOD': 1, 'OUTPUT': shp_outErfFix})
Some pointers on what to do or where to read would be great.
Thanks in advance,
Zoltan
Zoltan Szecsei GPrGISc 0031
Director, Geograph (Pty) Ltd.
GIS and Photogrammetric Services
Cape Town, South Africa.
Mobile: +27-83-6004028 (Signal, not WhatsApp)
+974-5058-8729
+36-20-4808362
www.geograph.co.za
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240311/3661a390/attachment.htm>
More information about the QGIS-User
