[Qgis-user] "QgsProcessing" has no attribute 'run' (same for 'processing')
Johannes Kröger (WhereGroup)
johannes.kroeger at wheregroup.com
Mon Mar 18 00:31:43 PDT 2024
Hi Zoltan,
the most important thing first: Don't fall into the "AI can program"
mindset trap. You *will* end up with nonsense like this if you do. Those
tools can often hallucinate non-existent APIs and mislead you. They
might work for some more basic or wide-spread code bases but so far I
have seen very bad results for PyQGIS. Best search the web using
"pyqgis" as additional keyword to your query.
As https://qgis.org/pyqgis/3.34/core/QgsProcessing.html says, that class
only contains data to be used by Processing things. It is not your entry
point into using Processing via Python.
For that please see
https://docs.qgis.org/3.34/en/docs/user_manual/processing/console.html ,
written by actual, smart humans ;)
And for the Batch file: Don't write your own, QGIS comes with a perfect
one already, called |python-qgis[-ltr].bat| . See e.g.
https://gis.stackexchange.com/a/428577/51035
Cheers and good luck!
Hannes
On 11.03.24 09:30, Zoltan Szecsei via QGIS-User wrote:
> Hi,
> Apologies for asking help on what hopefully might turn out to be
> trivial, but I am pretty much blue in the face googling and asking
> Gemini for help.
> There are 2 questions in this email:
> I have a Windows 11 OSGEO4W installation QGIS 3.36.0 and grass (and more).
> I use PyCharm 2023.3.4 (Community Edition) - but not yet configured
> "nicely" for QGIS as I am mostly in a non-Open Source environment.
> Most of the stuff I write is python is for "problem fixes" and these
> python scripts ideally run on a windows command-line with a BAT file.
> So, in this scenario below, I keep getting: ..... *has no
> attribute 'run'
> *This whether I am running inside PyCharm or on the command-line
> through below batch job.
> *Question #1*
> *What is the correct bat file structure for running python scripts?*
> I currently have [below] but is it optimal?
> SET QGIS_PATH=C:\OSGeo4W\apps\qgis
> call "C:\OSGeo4W\bin\o4w_env.bat"
> SET PYTHONPATH=%QGIS_PATH%\python;%PYTHONPATH%
> SET PATH=%QGIS_PATH%\bin;%PATH%
> C:\OSGeo4W\apps\Python39\python.exe
> Z:\Projects\Development\python_QGIS\qgis_tests\qgisrun.py
> pause
> *Question #2*
> I have tried many various import options, but I cannot get past the
> *has no attribute 'run'* error from python below code:
> Minimalst as this code is, it should run without adding anything else,
> should it?
> from qgis.core import QgsProcessing
> shp_inErfPoly = 'Z:\\Erven_1February2024.shp'
> shp_outErfFix = 'Z:\\Erven_1February2024_FixGeo.shp'
> QgsProcessing.run("native:fixgeometries", { 'INPUT':
> shp_inErfPoly, 'METHOD': 1, 'OUTPUT': shp_outErfFix})
> Some pointers on what to do or where to read would be great.
> Thanks in advance,
> Zoltan
> Zoltan Szecsei GPrGISc 0031
> Director, Geograph (Pty) Ltd.
> GIS and Photogrammetric Services
> Cape Town, South Africa.
> Mobile: +27-83-6004028 (Signal, not WhatsApp)
> +974-5058-8729
> +36-20-4808362
> www.geograph.co.za
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
Johannes Kröger / GIS-Entwickler/-Berater
FOSSGIS Konferenz
20.-23. März 2024 in Hamburg
https://www.fossgis-konferenz.de/2024/
WhereGroup-Beiträge auf der FOSSGIS
https://wheregroup.com/unternehmen/aktuelles/
WhereGroup GmbH
c/o KK03 GmbH
Lange Reihe 29
20099 Hamburg
Germany
Tel: +49 (0)228 / 90 90 38 - 36
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240318/c5845fb2/attachment.htm>
More information about the QGIS-User
