[Qgis-user] "QgsProcessing" has no attribute 'run' (same for 'processing')
Zoltan Szecsei zoltans at geograph.co.za
Mon Mar 18 00:36:59 PDT 2024
Nice attitude, Hannes :-)
Yes, totally true about the AI trap. You can't write a program by
handing the logic over to a "well read entity"
I use it when my mind is plain out of google keywords.
In maybe half a dozen attempts with AI, I have only hit gold once.
Thanks for the links.
Regards,
Zoltan
On 2024/03/18 10:31, Johannes Kröger (WhereGroup) wrote:
> Hi Zoltan,
> the most important thing first: Don't fall into the "AI can program"
> mindset trap. You *will* end up with nonsense like this if you do.
> Those tools can often hallucinate non-existent APIs and mislead you.
> They might work for some more basic or wide-spread code bases but so
> far I have seen very bad results for PyQGIS. Best search the web using
> "pyqgis" as additional keyword to your query.
> As https://qgis.org/pyqgis/3.34/core/QgsProcessing.html says, that
> class only contains data to be used by Processing things. It is not
> your entry point into using Processing via Python.
> For that please see
> https://docs.qgis.org/3.34/en/docs/user_manual/processing/console.html
> , written by actual, smart humans ;)
> And for the Batch file: Don't write your own, QGIS comes with a
> perfect one already, called |python-qgis[-ltr].bat| . See e.g.
> https://gis.stackexchange.com/a/428577/51035
> Cheers and good luck!
> Hannes
> On 11.03.24 09:30, Zoltan Szecsei via QGIS-User wrote:
>> Hi,
>> Apologies for asking help on what hopefully might turn out to be
>> trivial, but I am pretty much blue in the face googling and asking
>> Gemini for help.
>> There are 2 questions in this email:
>> I have a Windows 11 OSGEO4W installation QGIS 3.36.0 and grass (and
>> more).
>> I use PyCharm 2023.3.4 (Community Edition) - but not yet configured
>> "nicely" for QGIS as I am mostly in a non-Open Source environment.
>> Most of the stuff I write is python is for "problem fixes" and these
>> python scripts ideally run on a windows command-line with a BAT file.
>> So, in this scenario below, I keep getting:       ..... *has no
>> attribute 'run'
>> *This whether I am running inside PyCharm or on the command-line
>> through below batch job.
>> *Question #1*
>> *What is the correct bat file structure for running python scripts?*
>> I currently have [below] but is it optimal?
>>     SET QGIS_PATH=C:\OSGeo4W\apps\qgis
>>     call "C:\OSGeo4W\bin\o4w_env.bat"
>>     SET PYTHONPATH=%QGIS_PATH%\python;%PYTHONPATH%
>>     SET PATH=%QGIS_PATH%\bin;%PATH%
>>     C:\OSGeo4W\apps\Python39\python.exe
>>     Z:\Projects\Development\python_QGIS\qgis_tests\qgisrun.py
>>     pause
>> *Question #2*
>> I have tried many various import options, but I cannot get past the
>> *has no attribute 'run'*  error from python below code:
>> Minimalst as this code is, it should run without adding anything
>> else, should it?
>>     from qgis.core import QgsProcessing
>>     shp_inErfPoly = 'Z:\\Erven_1February2024.shp'
>>     shp_outErfFix = 'Z:\\Erven_1February2024_FixGeo.shp'
>>     QgsProcessing.run("native:fixgeometries", { 'INPUT':
>>     shp_inErfPoly, 'METHOD': 1,  'OUTPUT': shp_outErfFix})
>> Some pointers on what to do or where to read would be great.
>> Thanks in advance,
>> Zoltan
>> Zoltan Szecsei GPrGISc 0031
>> Director, Geograph (Pty) Ltd.
>> GIS and Photogrammetric Services
>> Cape Town, South Africa.
>> Mobile: +27-83-6004028 (Signal, not WhatsApp)
>>          +974-5058-8729
>>          +36-20-4808362
>> www.geograph.co.za
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Johannes Kröger / GIS-Entwickler/-Berater
> FOSSGIS Konferenz
> 20.-23. März 2024 in Hamburg
> https://www.fossgis-konferenz.de/2024/
> WhereGroup-Beiträge auf der FOSSGIS
> https://wheregroup.com/unternehmen/aktuelles/
> WhereGroup GmbH
> c/o KK03 GmbH
> Lange Reihe 29
> 20099 Hamburg
> Germany
> Tel: +49 (0)228 / 90 90 38 - 36
> Fax: +49 (0)228 / 90 90 38 - 11
> johannes.kroeger at wheregroup.com
> www.wheregroup.com
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
         +974-5058-8729
         +36-20-4808362
www.geograph.co.za
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240318/f460a916/attachment-0001.htm>
More information about the QGIS-User mailing list
