[Qgis-user] Warning and errors netcdf when running a command
Langers, Fransje fransje.langers at wur.nl
Thu Mar 14 23:01:45 PDT 2024
Subject: Warning
I've used QGIS (version 3.34.3) for a few weeks now.
When I want to use a command from the toolbox processing (e.g. rasterize) I get the following warning: 'projection name Oblique_Stereographic in not part of the CF standard, will not be supported by CF! '
Followed by a number of errors:
ERROR 1: netcdf error #-62 : NetCDF: One or more variable sizes violate format constraints .
at (D:\src\osgeo4w\src\gdal\gdal-3.8.3\frmts\netcdf\netcdfdataset.cpp,netCDFDataset::SetDefineMode,3039)
ERROR 1: netCDF chunk fetch failed: #-39 (NetCDF: Operation not allowed in define mode)
ERROR 1: C:/Users/#/AppData/Local/Temp/processing_DbfCYS/1a30206c31d84010bc9572e8adfb0139/OUTPUT.nc, band 1: IReadBlock failed at X offset 0, Y offset 0: netCDF chunk fetch failed: #-39 (NetCDF: Operation not allowed in define mode)
ERROR 1: netcdf error #-39 : NetCDF: Operation not allowed in define mode .
at (D:\src\osgeo4w\src\gdal\gdal-3.8.3\frmts\netcdf\netcdfdataset.cpp,netCDFDataset::AddProjectionVars,6738)
at (D:\src\osgeo4w\src\gdal\gdal-3.8.3\frmts\netcdf\netcdfdataset.cpp,netCDFDataset::AddProjectionVars,6743)
at (D:\src\osgeo4w\src\gdal\gdal-3.8.3\frmts\netcdf\netcdfdataset.cpp,netCDFDataset::Close,2998)
I also get this warning when I use other commands.
Before, I could run these commands without getting these warning and errors. What do the warning and errors mean, and how can I fix it?
Best wishes
Fransje
Wageningen Environmental Research (WENR)
Fransje Langers
Onderzoeker Mens & Natuur
Team Regionale Ontwikkeling en Ruimtegebruik (ROR)
Environmental Sciences Group
Wageningen University & Research (WUR)
Postbus 47, 6700 AA, Wageningen
Wageningen Campus, Gebouw 101 (Gaia), Kamer B.217
Droevendaalsesteeg 3, 6708 PB, Wageningen
Tel. 0317 481677 (ma, di en do)
[cid:image002.png at 01DA76A6.A3D4EC60]
www.wur.nl/environmental-research<http://www.wur.nl/environmental-research>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240315/e9dd50c4/attachment.htm>
Type: image/png
Desc: image002.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20240315/e9dd50c4/attachment.png>
More information about the QGIS-User mailing list
